big bore kits
- Powerstroke_fan
Re: big bore kits
25 May 2012 21:51 - 25 May 2012 21:54
I think im gonna run the 1197J piston kit in a sleeved kz jug. to keep my compression up. and i think iam gonna hopefully pick up my new mk11 bottom end to start the build. then iam gonna switch over my head when i am ready for it. i was told i would have to run a base gasket spacer. to get my clearance. I talked about running my oil cooler earlier and i was thinking... I am waitning on my new high performance stator to arrive via elctrosport. But anyway i was thinking about getting a little fan to attach to the cooler and run it off a switch or possibly a thermostat. what do you guys think?? i would think that would help keep that 1197 engine cooler.
1977 KZ 1000 work in progress
Last edit: 25 May 2012 21:54 by Powerstroke_fan.
- 4TheKZ1000
Re: big bore kits
25 May 2012 22:25
I think you should listen to MarkII22. You have way to many irons in the fire. Slowdown and take a breath. You are sounding like me and I cant sleep at night with thoughts of cams, heads and carbs. I finally was able to slow things down and prioritize, focus and proceed. I do love the passion you have. You will get there.
- wireman
Re: big bore kits
25 May 2012 22:56Ive never seen an 1197 kit for j motor only the 1170Powerstroke_fan wrote: I think im gonna run the 1197J piston kit in a sleeved kz jug. to keep my compression up. and i think iam gonna hopefully pick up my new mk11 bottom end to start the build. then iam gonna switch over my head when i am ready for it. i was told i would have to run a base gasket spacer. to get my clearance. I talked about running my oil cooler earlier and i was thinking... I am waitning on my new high performance stator to arrive via elctrosport. But anyway i was thinking about getting a little fan to attach to the cooler and run it off a switch or possibly a thermostat. what do you guys think?? i would think that would help keep that 1197 engine cooler.
- Powerstroke_fan
Re: big bore kits
25 May 2012 23:03
ok well the company i was talking with made it sound like there was cuz i was asking him about a 1197 kit and he told me the pistons ran $30 more for j pistons i believe they woulda been mtc
- Powerstroke_fan
Re: big bore kits
25 May 2012 23:05 - 25 May 2012 23:29
But i believe you wireman you would know you guys are the kz gurus lol.but i was talking about fans earlier, do you think something like this would work? i thought about running two side by side and have them on a switch, so when iam in town on hot days in traffic i can turn them on.
www.powersportsmax.com/product_info.php/products_id/13229
Last edit: 25 May 2012 23:29 by Powerstroke_fan.
- APE Jay
Re: big bore kits
25 May 2012 23:56
1197 in a stock block is a great setup. We have done hundreds of them. I would not recommend the J pistons unless you are using a J head. That is also a common setup.
You have to run a .040" spacer under the block if you use J pistons.
- Powerstroke_fan
Re: big bore kits
26 May 2012 08:05 - 26 May 2012 08:10
So is there a 1197 j piston or not? iam running a j head. iam confused.I just want to get the right pistons for my motor.My 1075 pistons clear my j head without any spacers. so if i had to run kz pistons whats the most id have to do? put a spacer under the jug? from the sounds of it id have to do that either way. what do you guys think on the fan deal? is it worth doing?
Last edit: 26 May 2012 08:10 by Powerstroke_fan.
Re: big bore kits
26 May 2012 08:56
I like the fan idea.. Build the bottom end first to handle the power your planning.
- Powerstroke_fan
Re: big bore kits
26 May 2012 12:13
I am suspose to pick up the mk11 bottom end today and i already talked with the company that is gonna be doing the crank work and i got a undercut trans also. hopefully tonight i will get the mk11 bottom end tore down and get it ready to go out on tuesday.
- APE Jay
Re: big bore kits
26 May 2012 18:22Powerstroke_fan wrote: So is there a 1197 j piston or not? iam running a j head. iam confused.I just want to get the right pistons for my motor.My 1075 pistons clear my j head without any spacers. so if i had to run kz pistons whats the most id have to do? put a spacer under the jug? from the sounds of it id have to do that either way. what do you guys think on the fan deal? is it worth doing?
You have a Mk 2 engine and you are running a J model head? Or are you going to run a J head?
- DoubleDub
Re: big bore kits
26 May 2012 18:26Powerstroke_fan wrote: But i believe you wireman you would know you guys are the kz gurus lol.but i was talking about fans earlier, do you think something like this would work? i thought about running two side by side and have them on a switch, so when iam in town on hot days in traffic i can turn them on. www.powersportsmax.com/product_info.php/products_id/13229
Use a thermostat switch with an oil temp probe. I would only use the fans with an oil cooler, not sure if that's what you meant.
- andy9802gt
- If it tastes that good, eat it yourself.
Re: big bore kits
26 May 2012 21:10
Fans aren't needed. My brother runs a stock block 900 based 1230 with just a big bodied Lockhart oil cooler and has no heat issues. Ask around if there were going to be heat issues, that motor would have them. I hope you're sending your crank to Pearson since there is no better place. Undercutting second gear is cheap insurance. Also run the 10.25:1 pistons on the street since 13:1 is gonna take race gas to stop detonation. There's an 1197 in my future too if I don't sell my bike this year.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
