oil in the stator cover
19 May 2012 21:35 #523438 by spark23ca
oil in the stator cover was created by spark23ca
is there supposed to be oil in the stator cover ..the seal does leak a small small bit ..but there is a hole that shoots oil right out ..i think it has a passage way to the to the mag side crank bearing ..the stator cover has been beat on with a chisel it looks like and i'm pretty sure its twisting when i tighten it up and the gasket is not squeezing
1982 kz 1000 ltd ..someone started to make a bobber out of it and realized it didnt' run and they didn't know how to run their wrenches
19 May 2012 21:59 #523443 by Powerstroke_fan
Replied by Powerstroke_fan on topic oil in the stator cover
If its a kz 1000 or 900 it should have oil in stator
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
19 May 2012 22:39 #523453 by MFolks
Replied by MFolks on topic oil in the stator cover
No mag on the Z1's,Kz900's,Kz1000's or Kz1100's. It's a magnetic rotor spinning around/next to the stator of the alternator, providing A.C. to the regulator/rectifier charging the battery.
20 May 2012 03:32 #523497 by spark23ca
Replied by spark23ca on topic oil in the stator cover
thats what i thought ...these holes just must be a way for them to hold it while they cast it or maybe oil cooler lines...i know the main seal leaks a little ..but not too much...i'll figure it out i'll have posts of my build after i know more
21 May 2012 10:55 #523804 by Goalieguy35
Replied by Goalieguy35 on topic oil in the stator cover
That hole is for an alinement pin for the side case, so you cant mess up alinement.
1982 Kz750 w/ inverted gsxr front end. (sold) but forever missed
1980 z1000 cafe project w/76kz900 motor in it
80 kz 1000
81 kz1000
79 Yamaha xs 650
1979 kz 1000 LTD
1977 kz 1000 A
1977 kz 650 C
1978 kz 650
21 May 2012 22:37 #523918 by spark23ca
if its an alignment pin shouldn't i have a dowel pin there ..i have none ...theres dowels that around two of the bolt holes and then theres the idler wheel shaft that has to line up ..
