anyone ever had this problem????
  • wireman
  • Visitor
07 Jun 2006 20:28 #52790 by wireman
Replied by wireman on topic anyone ever had this problem????
Duck wrote:
it can do both but vacuum is not a common problem
AFAIK you pretty much need a leak between the combustion chamber and the crankcase that only happens on the intake stroke.
Can't think of any other way to get it.
I suspect that the gaskets were mangled when the thing was assembled. Hence my offer to swap the P5 motor with new pistons and rings for it...11K... if it ain't broke, it's probably still OK ;-)
its highly unlikely the gaskets were actually sucked in but the only way for that to technically happen would be for the bottem end to actually become a vacuam pump to suck the gaskets in ,im still putting my money on junk gaskets.:whistle:
  • Duck
  • e vica na i sau na ga
08 Jun 2006 04:59 #52847 by Duck
Replied by Duck on topic anyone ever had this problem????
maybe it happened on the airplane ride home from fbg. cabin to 10k ft and 92 degress to put pax to sleep. when landing slammed to sea level and 55 degrees to wake them up. breather got plugged and gaskets got pushed in, along with 3 pax hearing aids and one fontanel.
08 Jun 2006 18:37 #53070 by geerbangr
Replied by geerbangr on topic anyone ever had this problem????
I've never had any problems w/ FBG gaskets before but there is a first time for everything i guess,i'm gonna order a gasket set for it the first time my other half isn't looking,lmao,she's about had enough of me putting money in this bike,lmfaoooooooooooo.Thanx guys !!!!!
1978 KZ 1000
I go by Jason
08 Jun 2006 19:33 #53081 by Z1R rider
Replied by Z1R rider on topic anyone ever had this problem????
some high performance motors will have a crank case evacuation system to pull a couple inches of vacum in the crank case. does the motor have any hoses going from the crank case (or valve cover) to the header or maybe an air pump? just a thought
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
  • wireman
  • Visitor
08 Jun 2006 21:49 #53112 by wireman
i talked about using the smog ports on the emission motor heads and running them into collector on header to make a poor mans crankcase evacuation system before but there wasnt much interest in it
09 Jun 2006 18:58 #53270 by geerbangr
no guys there are no evac hoses hooked up,i have the smog ports plugged off.
1978 KZ 1000
I go by Jason
09 Jun 2006 22:23 #53315 by Indy636
Replied by Indy636 on topic anyone ever had this problem????
I hit 11,000 all the time and dont have any leaks. I use a clear 3/8 tube hooked to my vent housing nipple, and the other end going into a clear tupperware like container about the size of a baby bottle strapped to the frame. Its easy to see under the body if it would start to get oil in it, but it stays dry all the time. I have only heard good things about FBG, and have talked to Paul several times at the track and he really knows KZ& J motors. I will only use his clutches and carbs on my bike. I too have never had cover gaskets tear or be drawn in by the motor, even when I was down a cylinder. I like to use a little Yamabond on the gaskets, Its never fail me yet. Hope this helps.
10 Jun 2006 17:38 #53489 by geerbangr
thanx for the info indy.these guys on here act like 11 grand is unheard of w/ a j block,lil do they know how fun it is,lol .i plan on using a little glue when i regasket it so maybe tha'll help.thanx for the feedback indy
1978 KZ 1000
I go by Jason
  • wireman
  • Visitor
10 Jun 2006 19:00 #53511 by wireman
oh no 11,000 isnt impossible i just said ive never seen a streetbike motor make power to 11,000 rpms.ive spun 11,000 on a few occasions just for shits and grins but quit making power at around 9,000-9,500.the 1197 with 900 crank in my z1 will spin to the stars it dont start making power till 6500 then it hits like a sledgehammer i run out of :whistle: before it does by the time it hits 10,000 its doing more than i want to deal with.
  • wireman
  • Visitor
10 Jun 2006 19:02 #53514 by wireman
Post edited by: wireman, at: 2006/06/10 22:04
  • wireman
  • Visitor
10 Jun 2006 19:05 #53515 by wireman
wont hit 11,000 but itll spin to 8,000 pretty easy!:evil:
Post edited by: wireman, at: 2006/06/10 22:06
11 Jun 2006 14:11 #53722 by geerbangr
:evil: wireman that v drive in your picture is bada$$
that blown big block outta be makin some serious power
1978 KZ 1000
I go by Jason
