Oil Level
  • adr3naline
  • adr3naline's Avatar Topic Author
Oil Level
14 May 2012 12:37
#522284
Sorry if this is totally elementary... but I have a haynes manual and it doesn't say.
Do I need to have my 79 kz650d2 up on the center stand to determine oil level? Or just level?
Thanks!
adr3naline
1979 KZ650sr
1979 CB650
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Oil Level
14 May 2012 12:40
#522285
I vote for level
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: Oil Level
14 May 2012 13:53
#522296
Either. But would prefer center stand. Have you tried to balance level a bike off the center stand and try to look at that window? Sitting on the bike and trying to look only gets me dizzy, lol. Could end up with banged up bike. And on the center stand the engine has slight tilt forward. But I don't think the difference will matter much between the two methods.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
  • Medina
  • Medina's Avatar
Re: Oil Level
14 May 2012 14:33 - 14 May 2012 14:34
#522303
this makes me nuts...I try center stand, balancing on two wheels and looking...
both different, I pulled back on the handle bars and it moved. finding level ground to check seems like it moved again...I may just get an oil pressure gauge like I've seen here.
Mine does burn a bit of oil, 1/2 quart every 3-500 miles so I'm always looking AND always thinking my petcock leaked and filled the tank, or theres no oil in there at all...
maddening I tells ya, maddening.
I love my Asian engineer overlords but this is the one thing they did that leaves something to be desired.
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
Last edit: 14 May 2012 14:34 by Medina.
Re: Oil Level
14 May 2012 16:13
#522320
Either. The Owner's Manual says "With the bike level or on the center stand....." Of course, it is much easier to check with the bike on the center stand on level ground than trying to hold the bike level while getting your head low enough to see the site glass, so I have always used the center stand. Ed
Re: Oil Level
14 May 2012 18:37
#522348
For me and the other teeter-tottering, more or less uncoordinated staggering masses:
www.kzrider.com/forum/21-tools/318467-ea...l-level-check#318467
Good Fortune! :)
Re: Oil Level
14 May 2012 18:47
#522349
I thought you used OMR's old high school trick and glued a mirror to the tip of your shoe. Of course, it wasn't motorcycle oil he was checking out. :laugh: :laugh:
  • RonKZ650
  • RonKZ650's Avatar
Re: Oil Level
14 May 2012 22:49
#522411
Of course as mentioned, either method works, but of course putting on the centerstand does not guarantee the bike is perfectly level. You need perfectly level pavement to get accurate level on the centerstand. I prefer to have the bike on the sidestand and kneel down beside it and tip it up to level. You can feel the point of balance and that will be where you want to do your check, and also watch the oil rise in the glass as you tip it up level. Another trick for KZs that use some oil is to maintain your oil level at the lower mark instead of the full mark. This can cut oil consumption quite a bit.
  • adr3naline
Re: Oil Level
15 May 2012 00:13
#522438
Thanks all!
adr3naline
1979 KZ650sr
1979 CB650
