Can one remove starter clutch w/o removing clutch?
12 May 2012 21:56 #521872 by Juan1
I'm trying to replace the starter clutch on my 1982 GPZ750r, but the nut holding the clutch to the bike won't budge. I don't have impact tools to use, but my breaker bar attempts were unsuccessful in removing the 30mm clutch nut. Is there any way to remove the secondary shaft without removing the starter clutch?
  • wireman
12 May 2012 22:13 #521876 by wireman
Starter clutch is on other side of motor under stator cover B)
12 May 2012 23:04 #521889 by Juan1
I hope you're right. The manual shows that the clutch needs to be removed to get at some bolts, the oil pan needs to be dropped and then the secondary shaft, which holds the starter clutch, can be accessed.
12 May 2012 23:22 #521897 by baldy110
Wireman is incorrect on this one he is right for the 1000 series engine but the KZ750R is based on the KZ650 engine. The answer is yes you do have to remove the clutch. The is no way around that.
13 May 2012 00:09 #521906 by steell
Juan1 wrote: I hope you're right. The manual shows that the clutch needs to be removed to get at some bolts, the oil pan needs to be dropped and then the secondary shaft, which holds the starter clutch, can be accessed.
That is correct, that or a big hammer to break the case :evil:
  • wireman
13 May 2012 13:01 #522058 by wireman
baldy110 wrote: Wireman is incorrect on this one he is right for the 1000 series engine but the KZ750R is based on the KZ650 engine. The answer is yes you do have to remove the clutch. The is no way around that.
My bad,Im used to the 900/1000/1100 series motors I guess :)
