Thread repair?
08 May 2012 16:15 #520752 by tito
Thread repair? was created by tito
Taped hole in cylinder head at cam plug is worn out and the bolt can't be tightened also I got oil leak from there. :pinch:
What would be the best method to repair it? Longer bolt may solved it but I was wondering what's the best way to fix it.
Thanks!
08 May 2012 16:41 - 08 May 2012 16:41 #520759 by 531blackbanshee
Replied by 531blackbanshee on topic Thread repair?
my method(is like opinions)
goes:
heli-coil
after that pulls out:
timesert
step stud (if possible)
finally:
weld up and re-machine a new hole and cut new threads and start over.
thats my .02,
ymmv.
Last edit: 08 May 2012 16:41 by 531blackbanshee.
The following user(s) said Thank You: tito
08 May 2012 17:26 - 08 May 2012 17:31 #520772 by baldy110
Replied by baldy110 on topic Thread repair?
Last edit: 08 May 2012 17:31 by baldy110.
08 May 2012 17:30 #520774 by baldy110
As a temp fix I have used a longer 6x1 bolt and installed a nut on the end. That got me by for years until I pulled the head off during a rebuild. At that time I tapped and installed a heli coil. The heli coil is still there after 20+ years.
08 May 2012 19:22 #520803 by tito
Replied by tito on topic Thread repair?
Leon and baldy,
Thank you very much for your sugestions. I understand that the best method would be heli coil. I will do when I open the head. In the meantime, I will use longer bolt and nuts to fasten the head cover. :laugh:
