81 GPZ 550 oil leak behind front sproket...maybe
03 May 2012 21:13 #519667 by dfinnegan71
As the stated in the title It seems I have an oil leak that acts like an automatic chain lube system. Meaning my chain constantly shows signs of excessive oil on it. It actully drips on the garage floor after an ride of just a couple dozen miles.
My question is how much is involved in changing the oil seal on that there drive shaft that the sproket is connected to? Could it be coming from something else? I have searched this forum but didn't find the answer. Thanks in advance for your help.
1981 GPZ 550 mild custom
  • Kawickrice
03 May 2012 21:22 #519669 by Kawickrice
Replied by Kawickrice on topic 81 GPZ 550 oil leak behind front sproket...maybe
Scratching my head an that question
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
03 May 2012 21:50 #519680 by dfinnegan71
Replied by dfinnegan71 on topic 81 GPZ 550 oil leak behind front sproket...maybe
My chain is always dripping wet with oil. Great for lube but I never had a bike oil the chain for me like this. When I had the chain guard off it would spray all over the tire, fender, brake light and my left foot. Now that the guard is back on it's a contained mess, but a mess nonetheless.
I guess what I am wondering is what needs to be taken apart to change the seal on the shaft that the front sprocket is attached to. Can the old oil seal be taken off and a new one put on while the engine is in the frame? Am I totally an idiot and there is someting else I am completely missing? I hope that clarifies my question.
04 May 2012 00:13 #519724 by SPARKY47
Remove cover.
Remove sprocket.
Screw 2 woodscrews into seal one each side.
Use pliers to pull on screws to pull seal out.
Fit new seal.
Assemble.
Race local police.
Get slapped by wife/girlfriend/boyfriend.
Take no more notice of lunatics on the web.
:kiss: :woohoo:
1980 KZ500 B2
04 May 2012 00:17 #519725 by dfinnegan71
Thanks Sparky! That's what I was hoping for, an easy step by step instructional tutorial! You sir, rock the casbah!!
The following user(s) said Thank You: SPARKY47
09 May 2012 23:34 #521131 by dfinnegan71
Anyone know what they call that seal? I am on bike bandit and can't find it. Secondary shaft seal? I don't know.
09 May 2012 23:54 - 09 May 2012 23:54 #521135 by 650ed
Which item in the diagram below is the problem?
Attachment 000000_2012-05-09.jpg not found
Last edit: 09 May 2012 23:54 by 650ed.
10 May 2012 17:14 #521283 by dfinnegan71
Thanks you 650ed! It turns out that, apon furhter inspection, it is the shift shaft seal. looks like 92049B. Does that just pull out and the new one slide in? Should I drain the engine oil first? Thanks in advance.
10 May 2012 17:55 - 10 May 2012 17:56 #521292 by 650ed
I've never changed one, so I can't say how to do it, but it might be best to drain the oil - just in case. The part number for the piece labeled 92049B is shown as 92051-005. The good news is that it is still an active part, so any Kaw dealer can order it. Ronayers.com lists the price as $3.51. Ed
Last edit: 10 May 2012 17:56 by 650ed.
10 May 2012 18:04 #521295 by turboguzzi
Replied by turboguzzi on topic 81 GPZ 550 oil leak behind front sproket...maybe
all those seals are pretty standard measures and available off the shelf in a good hydraulics supply shop.
while you are there would change the three of them to avoid further hassle in the future.
10 May 2012 19:33 #521314 by dfinnegan71
Thanks tuboguzzi, good advice. Do you think the cover needs to come off or came I pull the old one out and slide the new one in? That's what she said....!! :woohoo:
12 May 2012 13:17 #521803 by turboguzzi
there's such a thing called seal puller would let you do it without pulling the cover off, easy with the mainshaft seal, less so with smaller ones.
