Tuned head swap
  • munkybrain2010
  • munkybrain2010's Avatar Topic Author
  • Clueless..
Tuned head swap
01 May 2012 21:01
#519202
Today I found out that my 2 cyl has horrible compression. It should have 170 +-15 psi but it has 140 and i can touch it even after a long ride. the rest are only around 150. my bike doesnt run too bad considering and I was thinking about doing a valve adjustment and making sure all the valves were in good shape soon.
My question is since I have another head can I just adjust the valves on that one and swap it to the one on my bike? I figured this would save some time waiting for parts and the new head gasket might help a little with the low psi if it is indeed ring issues and not a stuck or bent valve.
Keep it together man!
79 KZ650 "Geto Cycle"
  • DoubleDub
  • DoubleDub's Avatar
Re: Tuned head swap
01 May 2012 23:12
#519231
140 shouldn't cause cold exhaust. Sounds like you're having other issues. Doubt the head gasket will help - I would adjust the valves and check you spark/ignition if that doesn't help.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Tuned head swap
02 May 2012 01:21
#519253
Try retorquing your head.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • baldy110
  • baldy110's Avatar
Re: Tuned head swap
02 May 2012 12:22
#519330
140 pounds is not "horrible" compression. I have engines run really well with compression as low as 80 pounds. You have another issue other than compression here.
  • zed1015
  • zed1015's Avatar
Re: Tuned head swap
02 May 2012 13:09
#519347
munkybrain2010 wrote: My question is since I have another head can I just adjust the valves on that one and swap it to the one on my bike? I figured this would save some time waiting for parts and the new head gasket might help a little with the low psi if it is indeed ring issues and not a stuck or bent valve.
Simple answer. YES.
  • DoubleDub
Re: Tuned head swap
02 May 2012 13:29
#519353
Simple answer. YES.
He's right, I was just trying to point out that swapping the head won't necessarily resolve the issue. I hope you didn't take that wrong. The FSM I have says 90psi is when you might start having combustion issues related to compression.
Re: Tuned head swap
02 May 2012 14:01
#519360
Simple answer. YES.
Yes?? Please explain how replacing the head and the head gasket will help with a ring issue? I don't see the connection. :dry: Ed
  • zed1015
  • zed1015's Avatar
Re: Tuned head swap
02 May 2012 16:15 - 02 May 2012 16:18
#519376
Well! Am i the only one who fully reads posts before replying ?
I said YES to his SPECIFIC question regarding preparing his spare head to swop.
It will save time waiting for parts as he was going to do the valves anyhow.
I never said anything about rings.
The text regarding rings and gasket was a STATEMENT he made NOT A QUESTION.
Last edit: 02 May 2012 16:18 by zed1015.
Re: Tuned head swap
02 May 2012 16:35 - 02 May 2012 16:40
#519381
zed1015 wrote: "Well! Am i the only one who fully reads posts before replying ?"
Simple answer. YES. :laugh:
Last edit: 02 May 2012 16:40 by 650ed.
  • munkybrain2010
  • Clueless..
Re: Tuned head swap
04 May 2012 14:33
#519820
Right on thank you! What would the cold exhaust be related to?
i assumed it was my compression because the cold pipe is the cylinder with low compression. I mentioned the head gasket because mine doesnt seem to be spewing any air or oil but there is a ring of oil around the mating surface, is this normal? Will a retorquing help?
It actually doesnt run bad at all and idles pretty nicely.
I also just replaced the coils with brand new emgo 4ohm's.
Ive pretty much resigned myself to just letting the engine blow up since I have experienced every problem with this bike and I was pretty fed up. I may just take off the valve cover and check it out before i do that though since I can tool around on my Seca.
Thanks every one sorry for throwing like 10 questions into one post but Im so close to having a smooth running bike... you know the feeling ;)
  • DoubleDub
Re: Tuned head swap
04 May 2012 16:41
#519835
My first guess with 140psi would be too rich or no spark.
  • TexasKZ
  • TexasKZ's Avatar
Re: Tuned head swap
04 May 2012 18:54
#519848
A pipe cool enough to touch after a ride is a sure sign that that cylinder is not firing at all. To make a bang, all you need is fuel, air, compression and spark. Since compression is present, one of the others is missing.
Re-torquing the head may stop the oil leak. It's certainly worth a try.
