1984 GPZ 1100 cam lobe hight
- LarryC
05 May 2012 18:45 #520029
by LarryC
Same concept on the intake side but for different reasons. A round port runner on the intake side will have a tendency to draw the fuel as a stream rather than spread it out. Flat floors buy your 2 things.
1 - area over the short side
2 - the potential for the fuel to spread out.
On the intake side, the floor is not dead like the exhaust side. It tends to be fast.
Larry C.
Replied by LarryC on topic 1984 GPZ 1100 cam lobe hight
zed1015 wrote: Bit unsure what you mean by 'D' porting the intakes ?
'D' porting the exhaust(leaving the port floor relatively untouched)is standard practice.
Larry C.
- man-of-war
- Thank you received: 1
06 May 2012 06:30 #520141
by man-of-war
Replied by man-of-war on topic 1984 GPZ 1100 cam lobe hight
# 1 INTAKE GAP= 0.55mm
SHIM=2.00mm =240
#2 INTAKE GAP= 0.40mm
SHIM=2.20mm =245
#3 INTAKE GAP= 0.30mm
SHIM=2.15mm =230
#4 INTAKE GAP= 0.40mm
SHIM =2.00mm =225
#1EXHAUST GAP=0.25mm
SHIM=2.00mm =210
#2EXHAUST GAP=0.30mm
SHIM=2.10mm =225
#3EXHAUST GAP=0.30mm
SHIM=2.10mm =225
#4EXHAUST GAP=0.40mm
SHIM=2.20mm =245
I'm looking for a 13mm gap ??? for all[/quote]
Add shim size fitted to current gap size and deduct gap required (this case.15mm) gives you shim required.
Factory quoted maximum is .15mm which is the gap i have quoted for.
I wouldn't go below .10mm[/quote]
this is what I got for the valve clearance
# 1 INTAKE GAP= 0.18mm
SHIM=2.45mm
#2 INTAKE GAP= 0.14mm
SHIM=2.50mm
#3 INTAKE GAP= 0.15mm
SHIM=2.30mm
#4 INTAKE GAP= 0.16mm
SHIM =2.25mm
#1EXHAUST GAP=0.16mm
SHIM=2.10mm
#2EXHAUST GAP=0.15mm
SHIM=2.25mm
#3EXHAUST GAP=0.13mm
SHIM=2.25mm
#4EXHAUST GAP=0.16mm
SHIM=2.55mm
I'm done with this valve adjustment for now.I had to take the head to the shop twice yesterday for heli coils.#1 Intake bothers me,but it's in spec.
SHIM=2.00mm =240
SHIM=2.20mm =245
SHIM=2.15mm =230
SHIM =2.00mm =225
SHIM=2.00mm =210
SHIM=2.10mm =225
SHIM=2.10mm =225
SHIM=2.20mm =245
SHIM=2.45mm
SHIM=2.50mm
SHIM=2.30mm
SHIM =2.25mm
SHIM=2.10mm
SHIM=2.25mm
SHIM=2.25mm
SHIM=2.55mm
- LarryC
06 May 2012 09:41 #520152
by LarryC
SHIM=2.45mm
SHIM=2.50mm
SHIM=2.30mm
SHIM =2.25mm
SHIM=2.10mm
SHIM=2.25mm
SHIM=2.25mm
SHIM=2.55mm
I'm done with this valve adjustment for now.I had to take the head to the shop twice yesterday for heli coils.#1 Intake bothers me,but it's in spec.[/quote]
I would tip #1 exhaust before bolting the head on...
Larry C.
man-of-war wrote: # 1 INTAKE GAP= 0.55mm
SHIM=2.00mm =240
SHIM=2.20mm =245
SHIM=2.15mm =230
SHIM =2.00mm =225
SHIM=2.00mm =210
SHIM=2.10mm =225
SHIM=2.10mm =225
SHIM=2.20mm =245
SHIM=2.45mm
SHIM=2.50mm
SHIM=2.30mm
SHIM =2.25mm
SHIM=2.10mm
SHIM=2.25mm
SHIM=2.25mm
SHIM=2.55mm
Larry C.
- man-of-war
06 May 2012 23:57 #520395
by man-of-war
SHIM=2.45mm
SHIM=2.50mm
SHIM=2.30mm
SHIM =2.25mm
SHIM=2.10mm
SHIM=2.25mm
SHIM=2.25mm
SHIM=2.55mm
I would tip #1 exhaust before bolting the head on...[/quote]
Larry YOU SHOULD HAVE BEEN A TEACHER. I'm glad you posted that formula for the next guy !!
I will tear into the valvs next week
Larry could you explain how to tune this engine with the timing light? when gearing down I can hear a mild poping/backfire.
SHIM=2.00mm =240
SHIM=2.20mm =245
SHIM=2.15mm =230
SHIM =2.00mm =225
SHIM=2.00mm =210
SHIM=2.10mm =225
SHIM=2.10mm =225
SHIM=2.20mm =245
SHIM=2.45mm
SHIM=2.50mm
SHIM=2.30mm
SHIM =2.25mm
SHIM=2.10mm
SHIM=2.25mm
SHIM=2.25mm
SHIM=2.55mm
- man-of-war
10 Aug 2012 19:14 #541813
by man-of-war
Hi guys I was wondering if someone could clarify the talk about the valve and shim clearance...
Is it true that the INTAKE VALVES are to open longer/bigger than the EXHAUST VALVES??
By doing this it will increase the bikes performance with pull off and mid band speed but sacrifice top end speed?
THESE ARE MY PRESENT VALVE CLEARANCES:
EXHAUST # 1 .13mm
# 2 .12mm
# 3 .12mm
# 4 .12mm
INTAKE #1 .11mm
#2 .13mm
#3 .13mm
#4 .13mm
Thanks!
EXHAUST # 1 .13mm
# 2 .12mm
# 3 .12mm
# 4 .12mm
INTAKE #1 .11mm
#2 .13mm
#3 .13mm
#4 .13mm
Thanks!
