Valve cover & auto tensioner
  • martin_csr
  • martin_csr's Avatar Topic Author
18 Apr 2012 20:15 - 21 Feb 2013 15:26
#516550
1981 KZ650-CSR w Hy-Vo cam chain & automatic cam chain tensioner (cross wedge type).
When removing or installing the valve cover, was I supposed do anything w the tensioner?
I did not remove the camshafts or anything... just the valve cover.
Last edit: 21 Feb 2013 15:26 by martin_csr.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Valve cover removal & auto tensioner
18 Apr 2012 20:31
#516551
On a KZ 1000 they are unrelated. Cover can be removed without effecting any internal motor systems
  • loudhvx
  • loudhvx's Avatar
18 Apr 2012 21:26
#516562
On the 550's you must release the camchain tension before installing valve cover.
Once the cover is off, if the chain slack is taken up, when you put the cover back on, it pushes down on the chain increasing the tension several fold. This chews up guides and may stretch the chain.
I haven't confirmed any of this for a 650, though.
There should be warnings in the manual for this.
  • martin_csr
Re: Valve cover
18 Apr 2012 22:09 - 21 Feb 2013 15:20
#516576
Thanks. There is a note in the manual that I overlooked, but it's not really a warning or caution that is typically found elsewhere in the manual.
Last edit: 21 Feb 2013 15:20 by martin_csr.
  • martin_csr
Re: Valve cover
18 Apr 2012 22:49 - 21 Feb 2013 15:21
#516587
[IMG]image gone[/img]
Last edit: 21 Feb 2013 15:21 by martin_csr.
  • Motor Head
  • Motor Head's Avatar
19 Apr 2012 09:57
#516637
Yes just as the manual says, you need to either remove the tensioner from the back of the cylinder block. Or take the cap loose from the cross wedge, and remove the spring and cross wedge. Removing the wedge will let the chain push the plunger back in for the tensioner. With the wedge in place, well you are exerting forces on the guides and chain that it was not designed for. It would be possible to have damaged the guides, but those chains are pretty strong, I would doubt it would be damaged but it would be a possibility. The guides though are the weaker of any of the parts.
  • martin_csr
Re: Valve cover
19 Apr 2012 13:17 - 21 Feb 2013 15:27
#516681
Thanks.
Last edit: 21 Feb 2013 15:27 by martin_csr.
  • martin_csr
Re: Valve cover
19 Apr 2012 18:40 - 21 Feb 2013 15:21
#516711
  • saxonpirate
  • saxonpirate's Avatar
  • 1983 KZ1100 LTD
19 Apr 2012 20:00
#516730
Very interesting and informative post. Trouble is its got me thinking. I've just had the cam cover off of my Z1100 Ltd to sort the leaks in the end caps. The chain definitely had some slack in it, and I'm hoping this procedure doesn't apply to my bike...
Oh for a stress free life... :ohmy:
1983 KZ1100 LTD..
Ride like your life depended on it :-)
  • LarryC
  • LarryC's Avatar
19 Apr 2012 20:23 - 19 Apr 2012 20:31
#516738
saxonpirate wrote: Very interesting and informative post. Trouble is its got me thinking. I've just had the cam cover off of my Z1100 Ltd to sort the leaks in the end caps. The chain definitely had some slack in it, and I'm hoping this procedure doesn't apply to my bike...
It does apply but don't loose and sleep over it. I watched dealership mechanics do that all the time back in the mid 80's.
Larry C.
Last edit: 19 Apr 2012 20:31 by LarryC.
  • saxonpirate
  • 1983 KZ1100 LTD
20 Apr 2012 04:09 - 20 Apr 2012 04:10
#516821
Well that will teach me one thing Larry. Look at my service manual next time I do a supposedly simple job on the bike. Never too old to learn eh!
1983 KZ1100 LTD..
Last edit: 20 Apr 2012 04:10 by saxonpirate.
  • martin_csr
Re: Valve cover
20 Apr 2012 10:31 - 21 Feb 2013 15:22
#516858
Last edit: 21 Feb 2013 15:22 by martin_csr.
