transmission
- andyhump
13 Apr 2012 10:37 #515570
by andyhump
transmission was created by andyhump
Hi could anyone help me out with this one i have a z1000 mk2 1015cc engine that was set up for shaft drive i want to put it back to chain drive i have replaced gears but not sure on the shift rods and shift drum i think i also have to change the gear and neutral position levers and springs
many thanks andy
many thanks andy
- Thank you received: 797
13 Apr 2012 11:19 #515577
by 531blackbanshee
Replied by 531blackbanshee on topic transmission
afaik,
you need to take the complete trans from a chain drive and install "everything"from the chain drive into the shaft drive.
if you can look at/measure all the pieces to confirm or deny fitment maybe you can piece it together.
the safe bet is to swap everything completely,that way you take the dumba$$ outta the middle.
- LarryC
13 Apr 2012 17:58 #515634
by LarryC
Larry C.
Replied by LarryC on topic transmission
Go to Bikebandit.com and lookup the part numbers on their schematics for the two models.
Larry C.
- etbike3135
- Thank you received: 50
13 Apr 2012 19:25 #515643
by etbike3135
1973 Kawasaki Z1
18 years in dragbikes
Replied by etbike3135 on topic transmission
Shift drums are different between chain and shaft, at least the outside where the lever turns it.
1973 Kawasaki Z1
