Split cases, old KZ pro needed...
11 Apr 2012 21:38 - 12 Apr 2012 22:26 #515315 by notaduc
Split cases, old KZ pro needed... was created by notaduc
I split my cases to get my crank out to take to John Pearson. Attached are photos of the bearing journal for the large trans bearing on the riders right, and the second one is the rightmost crank bearing journal.
These are the worst looking, but a couple have burrs on the edge, a bit hard to see in the photos, but there is also a spot that the trans gear rubbed the case, and there is a distinct ridge on the journal surface which you can make out here.
There seems to be about .040 side play if I push the rear trans gear assembly side to side.
1980 (mostly) KZ1000
Last edit: 12 Apr 2012 22:26 by notaduc.
  • Charles Nix
  • 1981 kz 1000c4
11 Apr 2012 22:50 #515334 by Charles Nix
Replied by Charles Nix on topic Split cases, old KZ pro needed...
I would not know But, I need more of your inner case pics please,especially the shift forks, If you could. Thank you .
11 Apr 2012 22:56 #515335 by notaduc
Replied by notaduc on topic Split cases, old KZ pro needed...
Charles Nix wrote: I would not know But, I need more of your inner case pics please,especially the shift forks, If you could. Thank you .
Its is lightly bolted back together and packed for my move next week. I can take some when I arrive as Ill be measuring backlash on my transmission shortly...
12 Apr 2012 22:25 #515501 by notaduc
Replied by notaduc on topic re
I was sure you dudes would be all over this...
12 Apr 2012 23:11 #515509 by racer54
Replied by racer54 on topic re
Not sure how much side play should be there but I wouldn't think it would be much. Those bearings should have a lock ring. You can see the groove in the case. If you have a ridge, that doesn't sound good either. Especially when you said a gear has been rubbing the case. Sounds like it has worn down the bearing surface. I have never run into any of these problems but they don't sound like something that you should have in there...something isn't right.
  • andy9802gt
  • If it tastes that good, eat it yourself.
13 Apr 2012 05:48 #515544 by andy9802gt
Replied by andy9802gt on topic Split cases, old KZ pro needed...
Worst case is knock the burrs and ridge off the case and replace the tranny bearings and the gear that was rubbing if it was damaged. The bearing shell doesn't spin and it's not a sealing surface so as long as its not way out of round it shouldn't hurt anything. Just make sure when you bolt it back together for real you have the locators in the groove on the bearing and cases or you'll be buying new cases anyway, ask me how I know. And good choice sending your crank to John.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
13 Apr 2012 06:09 - 13 Apr 2012 06:21 #515546 by Garn
Replied by Garn on topic Split cases, old KZ pro needed...
Did the bike slip out of second gear. It does seem to me that you have a shim washer missing on the sprocket/output shaft. This washer is just inside the ball-bearing with the groove in it. Can't remember, whether or not it is a "thick" washer, in this position.
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
Last edit: 13 Apr 2012 06:21 by Garn.
14 Apr 2012 09:59 #515725 by notaduc
I never rode the bike, I bought it as a frame/engine...
Ill sort through this when I land in CA...
If anyone else has experienced this or has ideas, Im glad to hear them in the mean time...
  • mark1122
  • Keep twisting it
14 Apr 2012 10:50 #515741 by mark1122
Replied by mark1122 on topic Split cases, old KZ pro needed...
just make sure the hole is still true, and deburr it. hard to give advice without seeing it.
like they said. there should not be side play with the locking ring in place. was the ring in there? i use locktite on the outside of the bearing, to keep them from spinning..
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
14 Apr 2012 10:52 #515742 by notaduc
The bearing has no sideplay, only the gears on the shaft... the ring is still in there.
  • mark1122
  • Keep twisting it
14 Apr 2012 15:48 #515788 by mark1122
it is normal to have a little side play there. just make sure u have all the shimms in the right place. the manual has several measurements for u to check.it has specs for the gears and the shafts.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
14 Apr 2012 17:31 #515794 by notaduc
I saw the gear backlash specs, but no side play measurements...
