- Thank you received: 3
Split cases, old KZ pro needed...
- notaduc
These are the worst looking, but a couple have burrs on the edge, a bit hard to see in the photos, but there is also a spot that the trans gear rubbed the case, and there is a distinct ridge on the journal surface which you can make out here.
There seems to be about .040 side play if I push the rear trans gear assembly side to side.
1980 (mostly) KZ1000
- Charles Nix
- 1981 kz 1000c4
- Thank you received: 5
- notaduc
Charles Nix wrote: I would not know But, I need more of your inner case pics please,especially the shift forks, If you could. Thank you .
Its is lightly bolted back together and packed for my move next week. I can take some when I arrive as Ill be measuring backlash on my transmission shortly...
- notaduc
- racer54
- Thank you received: 114
- andy9802gt
- If it tastes that good, eat it yourself.
- Thank you received: 18
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
- Garn
- Thank you received: 13
RegardZ.
1 x 73 Z1 (Jaffa), 74 Z1A, 76 Z900-A4
1 x 73 Yamaha TX500 & 98 fzx250 Zeal
Sydney Australia
- notaduc
Ill sort through this when I land in CA...
If anyone else has experienced this or has ideas, Im glad to hear them in the mean time...
- mark1122
- Keep twisting it
- Thank you received: 109
like they said. there should not be side play with the locking ring in place. was the ring in there? i use locktite on the outside of the bearing, to keep them from spinning..
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- notaduc
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- notaduc
