- Thank you received: 1656
Takes 100 kicks to start w/ dyna coils?
17 Apr 2012 11:43 - 21 Feb 2013 15:51 #516323
by martin_csr
Last edit: 21 Feb 2013 15:51 by martin_csr.
- zukdave
- Thank you received: 229
17 Apr 2012 23:35 #516408
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Takes 100 kicks to start w/ dyna coils?
The paper work with my dyna coils said solid core wires only
so thats what I run and it works.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 893cv
- Thank you received: 15
18 Apr 2012 01:53 #516439
by 893cv
1980 kz1000 LTD
1978 Z1R
Replied by 893cv on topic Takes 100 kicks to start w/ dyna coils?
This is from the Dyna web site installation instructions pdf file for the coils you have "Works with all types and sizes of spark plug wires"
www.powercommander.com/downloads/Support...C1-2_1-3_3-2_3-3.pdf
Yes, the coils you are using will work with solid core wires. The current instructions also say that resister wires will work just as well.
1980 kz1000 LTD
1978 Z1R
- Jonny
- woot!
18 Apr 2012 03:11 #516441
by Jonny
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
Replied by Jonny on topic Takes 100 kicks to start w/ dyna coils?
For what its worth I run Dyna Green coils, with my Dyna, and solid core wires (forget the brand, but the ones carried at Z1 in any case.)
I found the selection a little confusing between the gray and green coils, but when I researched it seems that a lot of people with 650/750s' had gone with the greens as well, so I went that way.
They've worked perfectly for me since installation, and I found that after install and timing, just a little adjustment of of the air screws was need to get dead on at idle (with the help of a colortune.) Jetting was already pretty damn good, so I didn't mess with it.
I did a similar once over of the bike trying to figure out what the problem was before swapping out the mechanical ignition for the Dyna, and cleaned alot of nasty connections and suchlike before finally spending the dollars on the Dyna. Turns out it was bad condensers. So... A somewhat expsensive fix, but I`ve been super happy with the results, she fires better a faster than before, presumably because of better voltage to the coils, and in increase in spark voltage with the new system. Keep at, I think ultimately you`ll be happy with the results.
Just my 2 cents.
Jon
Just my 2 cents.
Jon
'78 KZ 650C2 'Lila'
