Takes 100 kicks to start w/ dyna coils?
11 Apr 2012 20:34 #515301 by Lucid
Cleaned carbs (again, more thoroughly) but the bike still takes a long time to start, and when it does, it runs REALLY rich. I'm thinking now that it's the Dyna coils with the stock ignition. (previous owner updated from points to a newer electronic ignition)
I'm running Dyna 2.2ohm coils (grey ones) and the yellow spark plug wires. I have a set of the grey spark plug wires if those will work better, not sure about the difference but if I remember right, they're different. Also, a couple of the wires don't seem to be seating all the way on the coils. Like the rubber surround keeps it from being metal on metal, and you can push the plug wire in an extra 2mm or so into the coil (only to be pushed back out by the rubber, if that makes sense). I assumed this was normal because I was working with the same company, but I am beginning to question that now. I am getting spark to all plugs though, and proper voltage to the coils when key is on.
:angry: If someone has the stock coils and wires let me know, I'm sick of this thing not starting first kick like it used to on stock coils! (they were brittle though and the wires broke in my hand one day)
78 KZ650B Cafe
12 Apr 2012 01:10 #515351 by 893cv
Replied by 893cv on topic Takes 100 kicks to start w/ dyna coils?
Does the ignition system still include the oem ballist resister? The Dyna instructions say to remove it. Other then that, it sounds like you still have carb problems.
1980 kz1000 LTD
1978 Z1R
12 Apr 2012 08:55 #515385 by roy-b-boy-b
Replied by roy-b-boy-b on topic Takes 100 kicks to start w/ dyna coils?
Do you have 12 volts to the coils? I'll send you stock coils for Dyna but that don't make sence.
Do you need 2.2 ohm coils ?
Go through your wiring with a tester and check everything out.
12 Apr 2012 10:56 #515408 by BSKZ650
Replied by BSKZ650 on topic Takes 100 kicks to start w/ dyna coils?
when it starts try spraying some water on all 4 of the header pipes see if they sizzle the water that should tell you if you have a dead or weak running cyl.
77 ltd1000, current rider
76 kz900, just waiting
12 Apr 2012 12:22 #515426 by kaw-a-holic
Replied by kaw-a-holic on topic Takes 100 kicks to start w/ dyna coils?
Doesn't the Dynamic require 3 ohm coils?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
12 Apr 2012 21:28 #515492 by zukdave
Replied by zukdave on topic Takes 100 kicks to start w/ dyna coils?
I run these Dyna DC1-2 3.0 ohm mini coils
with the factory gpz Ing.
Start's with a half turn of the crank.
I'll go get a video.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
13 Apr 2012 16:38 - 13 Apr 2012 16:39 #515623 by Lucid
Replied by Lucid on topic Takes 100 kicks to start w/ dyna coils?
At the battery is around 12.5volts, and I lose a little through the wiring but I do get almost 12v at each coil with key on. This is the same I got with stock coils and it ran fine.
I'm not sure where I found it but everywhere I looked on the site when I first wanted to replace the coils said 2.2ohms with the yellow wires.
Zukdave those coils look like I'd get a "for sure" snap in connection of the wires vs. the ones I have now:
As you see on the coils, they get wider on the input as you get closer to the body, and the rubber from the wires seems to not let you push the wire all the way in. I even trimmed a little off of one of the wires but it didn't help. If those Dyna 3ohm coils work with my 78, I'll switch to them. (or just back to stock, which I may just do)
78 KZ650B Cafe
Last edit: 13 Apr 2012 16:39 by Lucid.
13 Apr 2012 16:43 #515625 by Lucid
BTW my wiring is all removed and simplified down to:
Battery -> Key -> (1) -> fuse ->head and tail lights. (2) -> fuse -> igniter, coils, reg/rec. That's pretty much it if I remember right.
78 KZ650B Cafe
14 Apr 2012 19:46 #515815 by zukdave
With Dyna coils you MUST run solid core wires.
Suppression core wires to not work right.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
15 Apr 2012 22:21 #516048 by notaduc
Replied by notaduc on topic Takes 100 kicks to start w/ dyna coils?
Im interested in knowing the outcome/solution here as I am going to run a similar setup, but with the oem electric ignition.
1980 (mostly) KZ1000
16 Apr 2012 02:49 #516093 by Lucid
After looking, I have Accel yellow plug wires which I assume are suppression core. (Don't think they made yellow in solid core)
Do you really think that's all it is? From reading, it looks like I need to do something to the plugs to get them to work with solid core wires. I duuno, motorcycle electronics is something I know only a little about. I can wire 12v here and splice it there but that's about it.
78 KZ650B Cafe
16 Apr 2012 20:26 - 16 Apr 2012 21:06 #516235 by 893cv
Dyna coils work just fine with suppression plug wires. I use them (the coils and suppression wires) on my YZF600, FJ1200, TDM850, KZ1000 B4 and XJ650RJ. I always use their suppression wires so I dont have to use resister plug caps.
zukdave wrote: With Dyna coils you MUST run solid core wires.
1980 kz1000 LTD
1978 Z1R
Last edit: 16 Apr 2012 21:06 by 893cv.
