- Thank you received: 8
Engine warm up time?
- Medina
when RPM starts to climb over where ever it started at, push in half way.
when idle starts to climb a bit from where ever that is, push in, if it idles smooth, zoom zoom
or pull out choke to almost half way.
When its warm full choke idle is lower than when its 40 out, hence the vague instructions.
1981 KZ1100 Vetter "Luminous Navy Blue" DAMN YOU COLOR CODES!
Medina, Oh
My Bike Thread
www.kzrider.com/forum/10-new-members/469298-from-ohio
- cpg
Current Bikes: KZ440 LTD and KZ305 CSR
- KraZy Chris
Chris
78 KZ1000, Middle TN
- bountyhunter
- Thank you received: 337
Ride or drive it slow. Letting it idle just wastes gas.JR wrote: Hmmmmm. Interesting
I always though that the best way to warm an engine was to run it.
- jeffasaki
- Thank you received: 44
then ride it
These bikes where designed to run warm
any internal combustion engine is
efi just complicates life buy letting a machine do what you should know how to do
I can fix a carb
I can shoot a computer
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- LarryC
bromz wrote: Bought a 81 kz1000 csr this spring. It was sitting 2 years. Cleaned carbs new plugs new air filter oil change. Bike is running great. Just curious how long does it take to warm up. When I start it I use full choke fires off instantly. Then right away go to half and in about 5 min its ready with no hesitation. Only thing I havent done is have the carbs synced. I have put about 200 miles on it and running great. Is this warm up time normal for this bike or do i need to adjust the pilot screws out a little more. I am at 1 1/4 turns wich is what the manual says. Thanks
[attachment:1]IMG-20120314-00054.jpg[/attachment]
5 minutes running on the enrichener is too long in normal riding temperatures. It's a great way to blue the header pipes.
If your bike is taking that long to warm up, the pilot circuits are lean. It does't matter if it's Pod filters or stock air box.
Full Choke to start a stone cold engine is normal for the stock CV carburetors, stock VM carburetors or VM29's.
Larry C.
- bromz
- 1981 kz1000 csr
- Thank you received: 2
- bromz
- 1981 kz1000 csr
:woohoo:
- LarryC
bromz wrote: Thanks Larry. I only need full chocke to start it then right away to half choke. but i do think i am running a hair lean. last time i rode it was 43 f that morning. its only gonna get warmer
43 is a tad chilly so you're not too far off. When summer hits you may not even notice a problem. Run some sea foam in your gas for a while and see if it gets better over time.
Larry C.
