KZ650B1 IT RUNS...HAPPY DANCE! Kind of.
  • elfmagic17
  • elfmagic17's Avatar Topic Author
21 Mar 2012 00:31
#510969
So I finally got my 650B1 to run, Kick start only at the moment(think the starter may be smoked or bad brushes) But it only runs with the choke on, and has no acceleration. I'm thinking its all the corosion on the points plate and maybe also damaged condensers (probablems resulting from sitting outside in a pasture for about 9 years). I'm just excited that it runs, Cant wait to get more parts to get this little rocket on the road. B)
Kenny Hicks
74 Honda CB550
  • steveo_4192003
  • steveo_4192003's Avatar
  • 77kz650b-1
Re: KZ650B1 IT RUNS...HAPPY DANCE! Kind of.
21 Mar 2012 19:24
#511097
I remember the first time fired up my b-1, it was so loud cause the pipes had bad holes in them. Its a great bike and once its running in tip top you'll be addicted, im am, and im now just getting parts around for my 810 upgrade.
Hope to see some pics soon!!
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • baldy110
  • baldy110's Avatar
21 Mar 2012 21:30
#511116
If it only runs with choke then your carbs need cleaning.
  • 2wheeladdict
  • 2wheeladdict's Avatar
21 Mar 2012 22:26
#511134
+1 clean the carbs!!!!!
80 KZ1000 LTD
81 Yamaha XJ650 maxim
84 CR60r
  • DoubleDub
  • DoubleDub's Avatar
21 Mar 2012 23:04
#511143
Maybe new carb boots too. Would be recommended if they are hard-ish anyhow.
Do you need a starter motor? I've got one. It's got your name on it if you need it.
  • elfmagic17
21 Mar 2012 23:19
#511149
baldy110 wrote: If it only runs with choke then your carbs need cleaning.
Cleaned them, but found the intake/carb holders leaking. Any suggestions on gaskets or a sealer that works good? Threebond? gasket paper? I took the condensers off today and will test them tomarow at work.
Dub, I want to remove the starter to see if it is repairable,(brushes, clean and reassemble or have new windings installed) but what would you want for the starterif that donr workout?
Kenny Hicks
74 Honda CB550
  • elfmagic17
21 Mar 2012 23:21
#511150
Ohh and I will be replacing the hardened air box boots with new ones from Z1E when funds are more loose.
Kenny Hicks
74 Honda CB550
  • DoubleDub
21 Mar 2012 23:22 - 21 Mar 2012 23:22
#511151
PM being sent.
Are the boots pliable/soft? If not, just replace them - probably the only real solution.
Which side is leaking? Closer to the air box or closer to the engine?
Last edit: 21 Mar 2012 23:22 by DoubleDub.
  • elfmagic17
21 Mar 2012 23:24
#511152
Engine side at the head.
Kenny Hicks
74 Honda CB550
  • DoubleDub
21 Mar 2012 23:25
#511154
Yeah, unfortunately the only real solution there will be to replace them. Some guys use silicone adhesive between the boots and the engine, but I'm not sure that's universally agreed upon.
  • elfmagic17
21 Mar 2012 23:32
#511156
steveo_4192003 wrote: I remember the first time fired up my b-1, it was so loud cause the pipes had bad holes in them. Its a great bike and once its running in tip top you'll be addicted, im am, and im now just getting parts around for my 810 upgrade.
I never heard this bike run the whole time I've had it and fell in Love with the first time I sat on it. The balance that it has when you sit in the saddle. I want to Put a 4-1 Vance and Hines or ZR750 exhaust on it and go cutting some curves with it.
Kenny Hicks
74 Honda CB550
21 Mar 2012 23:41 - 21 Mar 2012 23:41
#511159
DoubleDub wrote: Yeah, unfortunately the only real solution there will be to replace them. Some guys use silicone adhesive between the boots and the engine, but I'm not sure that's universally agreed upon.
+1 on replacing them. It's well worth it because the new ones will last a long time. Ed
Last edit: 21 Mar 2012 23:41 by 650ed.
