KZ650B1 IT RUNS...HAPPY DANCE! Kind of.
  • DoubleDub
  • DoubleDub's Avatar
Re: KZ650B1 IT RUNS...HAPPY DANCE! Kind of.
21 Mar 2012 23:47
#511161
Make sure you get new vaccuum nipples too. Not sure why the 650/750 boots are more expensive than the 900/1000 - must be a quantity thing - and then on top of it they don't come with the nipples like the bigger ones do. :unsure:
Ed - do you do anything to your boots to "condition" them? I'm assuming yours are still original :whistle:
22 Mar 2012 00:07 - 22 Mar 2012 00:10
#511165
:) I replaced the carb holders, rubber vacuum nipples, and carb to airbox boots about 10,000 miles ago. The funny thing is that the carb holders were leaking bigtime, but from the outside they looked perfect. The problem was a bunch of tiny cracks on the face of the holders where they mate with the cylinder head. The leak test revealed the leaks, otherwise I would have been chasing the poor idle problem forever. I was able to track down all NOS genuine parts, so from that standpoint they are original (not aftermarket). ;) I do use a tiny bit of special lube on the outside of the rubber surfaces, but I don't think that will actually preserve them after seeing where the cracks were. Ed
Last edit: 22 Mar 2012 00:10 by 650ed.
  • elfmagic17
  • elfmagic17's Avatar Topic Author
22 Mar 2012 00:25
#511171
Thanks ED and Dub, I will be replacing the holders too at some point then. Probably will try some things to get buy (till I get pissed and rip them off and throw them away :laugh: ) till I can afford them though
Kenny Hicks
74 Honda CB550
  • elfmagic17
30 Mar 2012 01:11
#512935
So last Sunday I pulled the advancer apart and cleaned and lubbed and got it all freed up and put it back together. Then I removed the top idler and cleaned the bolts and holes to get the oil out so I could apply some thread locking compound and torque the bolts to put the cam cover back on for the final time (until the next valve adjustment inspection). Then I removed the carb holders and applied a thin coat of GMS to the mating surfaces and reinstalled. Changed the oil and Filter today and fired Her up and WAHOOO!! Runs pretty darn good. :woohoo: So when I can afford the holders She should run like a champ. Now only $400 More and she will road ready :S . Slowly but surely. B)
Kenny Hicks
74 Honda CB550
  • elfmagic17
31 Mar 2012 01:52
#513111
Some Pics of my almost 5yr old Son Helping work on the KZ. Someone is a Bad Influence. :evil:
Attachment 0317121128.jpg not found
Attachment 0317121128a.jpg not found
Kenny Hicks
74 Honda CB550
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
02 Apr 2012 12:18
#513562
teachin him right i see :cheer: !
  • elfmagic17
02 Apr 2012 13:38
#513574
531blackbanshee wrote: teachin him right i see :cheer: !
Absolutly!! ;) B)
Kenny Hicks
74 Honda CB550
  • elfmagic17
18 Oct 2013 23:00
#610500
Since then I have got new tires,rear shoes,clutch lever, good used alloy wheels, new intake boots, air filter,rigged up the right control switch, repaired broken splice in illumination circuit in the gauge harness, reshaped and recovered the seat, replaced the blown headlamp and turn indicator bulb, replaced the battery, and cleaned the tank. Been riding it since july when I got it legal. Love the way this bike handles. This picture shows off the customized seat and cover real well.
Kenny Hicks
74 Honda CB550
  • 531blackbanshee
  • Vendor
  • Vendor
21 Oct 2013 10:23
#610686
very nice sir!
i bet you are having a blast riding it :evil: .
  • elfmagic17
14 Nov 2013 19:40
#613092
Love it! Wish there was more warm weather left in this year. But will sure enjoy it next year more. Thanks again for the owners manual I will use it whenever needed.
Kenny Hicks
74 Honda CB550
  • 531blackbanshee
  • Vendor
  • Vendor
15 Nov 2013 05:59
#613101
no problem i am glad i gave the manual to someone who is using it :) !
