- Thank you received: 47
Poppity poppity poppity
- BlackZ1R
- Kawasaki in my blood
Starting off, the engine was built years ago with factory '78 KZ pistons using a 903 jug bored for factory clearance on the 1015 pistons. New Kawi rings, cam chain, tensioner, rollers and guides. Recent valve job with new seals and valve clearance set. I did not build this engine and have not done a compression check yet. I do not know what the valves are set at now. I will check all of this when I dive in to tune this bike.
The bike has a Bassani Superbike pipe and 29mm smoothbores w/K&N pods. Running 120 mains and air screws at 1 turn out. I have been turning on the screws and found that 1 1/2 turns out creates more popping through the exhaust. 1 turn out seems to run best. I haven't had the carbs off to check pilots, I'm hoping there are 17.5s in them. The sync is also probably off on this bike because of moderate vibes and seems to labor to idle smoothly. Will check/set float level when I pull them off to clean and service.
The bike also has a full Dyna S ignition and Green coils. The PO said something about the coils weren't wired to the Dyna directions, and I haven't had the tank off to look at what he was referring to.
This is basically the exact same set up I had on my 1980 Z1-r back in the day, except for the pipe.
I don't remember my Z1-R ever having a popping noise in the exhaust and it idled way smoother than this bike.
The bike runs way to good for the carbs to be stopped up, but I know they will need a thorough cleaning when I pull them off.
Outside of doing a good carb cleaning and syncing, valve lash setting, and fresh plugs, what else could be causing this popping at low speeds and idling? Ignition related maybe?
I do get a spitback every now and then through a carb. So I will re-seal my manifolds when the carbs come off.
Sorry for the long post, and I most likely will "tune" the popping out of it with a full tune up, but I was looking for some good advice from the collective that may have stumbled onto this problem themselves.
It has been a long time since I had a KZ running. Feels good riding one again and I want it running like I know it can. ThanKZ.
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- moneypit
- Thank you received: 35
good luck
2-76 kz900
St Paul MN
- LarryC
Aslo, I've seen 29's Mic's like as little as 1/4 turn on the air screws. Some don'r respond progressively to air screw adjustments either. You may have only one cylinder causing the popping. If it's the carburetors and they like 1 turn out, try backing them to 3/4 turn.
Larry C.
- BlackZ1R
I agree on that part being the main difference than my set up on the Z1-R. The Bassani collector/mid pipe is HUGE compared to the MAC I have on the Z1-R.LarryC wrote: Every Bassani pipe I've seen on a Kawasaki has a large collector diameter. That can influence the low speed carburetion.
Larry, I did go in to 3/4 and to 1/2 turn on the air screw. Didn't seem to like going in. The last thing I did was pull each one out and spray carb cleaner through the air circuit. I'm going to go in a 1/4 turn at a time again and see if that helped.
Could the coils being wired incorrectly be giving me some ignition problems? Seems like the PO said they were inverted compared to the illustration in the instructions. I haven't pulled the tank yet to give it a look.
Kawasaki
- Thank you received: 2829
- Yorke2112
- Thank you received: 1
I will note that I was only comfortable adding the hotter plug after I had installed an oil cooler.
Yorke
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BlackZ1R
All intake manifolds had cracks at the head mating surface. Three Bond fix till I get new ones.
Pulled carbs down, cleaned and set floats @ 23mm, I don't have a fuel height gauge for the 17mm hex plug yet. Carbs have 17.5 pilots
Had two slides moving vertical from linkage wear. Stretched the linkage spring a tad and tightened that up. Sync was out, set mechanical sync. Will put it back together tomorrow and see how it runs.
I had a feeling the intakes were going to be cracked.
ThanKZ for the input.
Kawasaki
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- BlackZ1R
N/A x 2Powerstroke_fan wrote: If its popping when you decel you might wanna plug the exhaust emmission ports, just a thought.
Kawasaki
- BlackZ1R
Two of the carbs had float heights set on 20-20.5mm from gasket surface when I went in them. Set them all on 23mm.
I really need to set the fuel level in the carbs with a gauge to get it perfect, but they're closer now. I can tell it did lean the idle out a bit, as I am at 3/4 turn on my air screws now.
The bike is a lot crisper sounding and feels responsive just blipping the throttle. Raining and tornado watch today, no test ride.
Would I be better off going to #20 pilots to get the air screws opened back up to 1 1/2 turns out.
Idle speed wonders a bit. Not super steady yet.
Here is what's in the carbs now:
1.5 slide cutaways
17.5 pilots
120 mains
float height 23mm
air screw 3/4 turn out
K&N pods
Bassani 4-1 superbike pipe
Dyna S with green coils
valve lash .0035-.004 on all valves
mechanical carb syn, no running sync done yet
EDIT: Just looking at the Sudco catalog, it looks like I should have #25 pilots in these carbs.
Kawasaki
- Thank you received: 2098
