Ticking sound from top of engine
- BIGD
18 Mar 2012 20:33 #510512
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Ticking sound from top of engine was created by BIGD
I have a ticking sound coming from inside the cylinder head cover. Front left side from what I can tell. Removed cylinder head cover, and all looks ok. Could this be in the valve spring, lifter or shim area. Sound does increase with RPMs. Thanks Don
- Motor Head
- Thank you received: 391
18 Mar 2012 20:53 #510514
by Motor Head
Replied by Motor Head on topic Ticking sound from top of engine
This is on your 81 KZ1000?
Have you checked the Valve clearances?
The service manual in my signature will cover this on your bike. You will need to measure and possibly get some shims to adjust the clearances. You might be able to move a few around. Best to make a shim/ clearance map, and then order what you need. Z1enterprises.com will have the shims at a good price as well as a new valve cover gasket.
- Roca
- Thank you received: 2
18 Mar 2012 22:18 #510533
by Roca
1980 KZ550-C2 LTD Custom
Replied by Roca on topic Ticking sound from top of engine
I had the same thing going on with my 1980 kz550. I put half a can of stp version of seafoam. I noticed the ticking sound decreased. Gonna change oil soon to see if it cleared out all of the gunk.
- Powerstroke_fan
- Thank you received: 83
19 Mar 2012 18:49 #510692
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Ticking sound from top of engine
check your clearences
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
