Petrol in exhaust on KZ1100!
- fergieuk
DoubleDub wrote:
Patton wrote:
fergieuk wrote: ...still fuel in the exhaust!....
Suspect leaking float valve.
Combined with inoperative overflow circuit (if so fitted).
Likely, but 60% compression isn't from a leaky float valve.
not the brightest bike mechanic (actually a nurse :whistle: :whistle: ) so just use a diagnostic logic, so happy that float vale is shutting off fuel and there is a spark so.................
am I on the right lines thinking its probably a stuck inlet or exhaust valve? I have no desire to remove head unless I have to......thinking again (prob over-thinking :dry: :dry: ) would the lower compression be caused by a reduced cylinder volume if it was full of fuel???
does any of this make sense or do i need to think about it after a few beers and 12hours sleep :evil: :evil: :evil:
KZ1100D1
- Motor Head
- Thank you received: 391
- fergieuk
Motor Head wrote: Being the #1 carb/ cylinder with the flooding issue. Have you checked the diaphragm at the Fuel Petcock? It maybe hooked to the #1 cylinder, as opposed to #2 which would be factory. Just a thought.
How far do you live from Dundee in Scotland???
I am on my way to buy you a beer, :woohoo: :woohoo: :woohoo: :woohoo: Genius!!! Schoolboy error! connected it up wrong!!!!!! :blush: :blush: :blush:
KZ1100D1
- Thank you received: 2098
This is because the fuel level inside the carb is being properly limited by the carb internals.
While a closed petcock may prevent fuel entry into the carb, a correctly functioning carb doesn't care whether the petcock is ever turned off.
- fergieuk
Patton wrote: Where carbs are functioning correctly, fuel won't enter the crankcase.
Fair do's. I connected the pepcock to number 2 and now 1 is functioning fine......but now 2 & 3 not! I am going on a cruise for a week. Will get back to it on my return.
Cheers for now
Fergie
KZ1100D1
- Motor Head
Look for fuel coming from the petcock on the vacuum side of the diaphragm.
You should be able to disconnect the vacuum line, and plug off both ends. Also plug off any emission vacuum lines, or make sure all 4 of the nipples on your intakes are plugged/ sealed. Turn the petcock to "Prime",then it should run on all 4 if the rest is good.
Z1 Enterprises lists petcock diaphragms and petcock repair kits.
www.z1enterprises.com/Petcock-vacuum-dia...saki-Yamaha-307.aspx
www.z1enterprises.com/Petcock-Repair-Kit...saki-Yamaha-305.aspx
- fergieuk
KZ1100D1
- MFolks
- Thank you received: 540
1.Tire pressure; inflate to max amount shown on sidewalls by manufacturer.
2.Drive Train; lubed and adjusted chain, with litle to no "Tight Spots".
3.Brakes; put the bike on the centerstand & spin the wheels, looking for dragging brakes.
4.Air filter; should be clean with little restrictions.
5.Sparkplugs; a fresh set of plugs at recommended gap and heat range.
6.Fuel filter(if installed); a clean filter with no restrictions. The type for a car has restrictions, and is designed to be used with a fuel pump. Avoid the glass bodied type, as more than a few car and motorcycle fires have been caused by vibration cracking the filter.
