Petrol in exhaust on KZ1100!
- fergieuk
No1 exhaust cold! Checked plug and sparking away. Drained carb and tried to clear petrol but quickly built up again.
So can anyone help? Would a stuck open float valve do this or is it engine internals I should look at and if so what?
Cheers fergie
KZ1100D1
- Thank you received: 2236
- Chaotic Reason
- Thank you received: 15
Michael
1980 KZ1000 shaft drive
- Thank you received: 2098
- fergieuk
Suppose will also need to do an oil change when sorted as no doubt petrol sitting in piston will have seeped down!
I hope it's a straight forward fix as I have a very busy 6 months coming up and just want to do some miles rather than be in workshop when free and as much fun and practical my piaggio 2 stroke scooter is its only for in town.
KZ1100D1
- fergieuk
Did a compression test and no1 is about 60% of no4 so best guess now would be a stuck valve? Unless anyone else has great pearls of wisdom?
KZ1100D1
- DoubleDub
- Visitor
- fergieuk
KZ1100D1
- DoubleDub
- Visitor
No - clearances is just a valve cover off job. Check those first.
fergieuk wrote: ...still fuel in the exhaust!....
Suspect leaking float valve.
Combined with inoperative overflow circuit (if so fitted).
- DoubleDub
- Visitor
Likely, but 60% compression isn't from a leaky float valve.
- fergieuk
DoubleDub wrote: Wha?
ah yes, separate valve covers unlike my Yam XS11!
KZ1100D1
