hole in my head
- Kz luv
hole in my head
14 Mar 2012 10:10
[attachment:1]C:\fakepath\hole in head.png[/attachment]
:dry: I just had a valve job on my Z1 and fifteen miles down the road a big ass hole busted out. please look at the pic and tell me what you think caused this.
- Kz luv
- Motor Head
Re: hole in my head
14 Mar 2012 10:16
Spit a valve shim out the head. Can you say Hockey Puck. Ouch!
- dejavoodo41
Re: hole in my head
14 Mar 2012 10:17
+1 That's definitely a shim exit wound!
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Re: hole in my head
14 Mar 2012 10:40
Yup. Time to count the shims; I suspect you'll only have 7. Just curious, are you running the stock cams? Ed
- oldkaw
Re: hole in my head
14 Mar 2012 11:36
I've got a head like that !! Yep shim .... it probably can be repaired but a lot cheaper to find a replacement. Sorry dude.. If someone else did the work for you and did the valve job without checking your clearances before reassembly, I'd be having a talk with them.
2 1984 zn1100, 1 1985 projects
1984 zn700 oil cooler, kerker 4-1, mikuni 34's, k&n pods
1984 zn700 stock
1982 kz750m1 stock
1975 cb550k
1975 cb360t
1984 zn700 stock
1982 kz750m1 stock
1975 cb550k
1975 cb360t
- Kz luv
Re: hole in my head
14 Mar 2012 11:47
not stock cams running Web 110 grind, I took it back to the shop who I had do the work and he is getting in touch with the guy who actually did the valve work. I don't want to mention the shops's name, I know shit sometimes happen unfortunately it's always me who gets the short end of the stick or should I say the long end of the d!ck. :sick:
Re: hole in my head
14 Mar 2012 13:20 - 14 Mar 2012 13:24
the machinist who rebuilt the head is not the responsible party here.
the mechanic that assembled and shimmed(or not)the head is the responsible party.
i hope it works out for you.
Last edit: 14 Mar 2012 13:24 by 531blackbanshee.
- Kz luv
Re: hole in my head
14 Mar 2012 13:49
Good thing is he's taking responsibility and is going to make it right, can't really ask for more. Kinda wish I would've went with a 1075 and played it safe. Too many problems so far!!!
- Puffin
Re: hole in my head
14 Mar 2012 15:09What were the circumstances high Revs or was just the lumpy cam
Hope it all works out for you
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
Re: hole in my head
14 Mar 2012 15:20
Believe me when I tell you, I don't know what I'm talking about here so hopefully someone who does will clarify. With that warning, I found a reference to using shim under bucket for cams with 9mm or greater lift (see 5th and 6th paragraphs of the link). 9mm = .354" and according to the references I've seen the lift on a web grind 110 cam is .395" Seems like that would put it in the range of cams that may spit a shim with shim over bucket configurations. Did the folks performing the work on your engine mention this? Can anyone else add to this info? Ed
www.club4ag.com/faq_and_tech_pages/4A-GE%20camshaft_story.htm
Re: hole in my head
14 Mar 2012 15:28
Web, APE and I think Andrews recommend shim under bucket for any cam over .410 lift on the Z and J engines. Obviously different for Toy motors.
