Cam timing chain system.
  • notaduc
  • notaduc's Avatar Topic Author
Re: Cam timing chain system.
20 Feb 2012 23:28
#505377
Im not sure what you made in this photo?
I have a unit I cobbled together that looks like the tensioner in the center bottom, and I converted my semi auto tensioner to full manual...
Are you saying you made your own replacement for the rubber wheel?
1980 (mostly) KZ1000
  • zed1015
  • zed1015's Avatar
21 Feb 2012 07:41
#505445
notaduc wrote: Im not sure what you made in this photo?
No! I am now refering to the Liska idler sprockets.
The rubber wheels are only cheap (around £12 over here) so hardly worth the bother of making one as it would only be replaced with an identical item.
It is the idler sprockets i modify on the same principle as the liska.
I replace the worn out rubber center with aluminium (see bottom right of pic)
Also the tensioner wheel on the metal bracket is originally rubber and wears out.
The Z9/1000 bracket won't take a sprocket as the rubber wheel is a smaller diameter.
I use a Z650 bracket which has more clearance and will take an idler sprocket.
  • notaduc
21 Feb 2012 15:59
#505496
I have a kz650 assy that I did the same thing with.
Im curious why you replace the rubber? Seems to only function to quiet the chain. Liska gears have nothing.
  • zed1015
  • zed1015's Avatar
21 Feb 2012 19:18
#505531
The rubber degrades,goes brittle and loosens over time making the gears un-usable.
Replacing this with billet extends their life and saves money on buying replacements,they are just as good as liskas etc.
I have found that there is no increase in noise and out of all my engines you can't tell which ones have had these fitted and which ones have the originals still in.
  • notaduc
21 Feb 2012 21:24
#505549
Please excuse my ignorance, but what purpose does the rubber or replacement aluminum serve?
  • zed1015
  • zed1015's Avatar
21 Feb 2012 22:41 - 21 Feb 2012 22:44
#505562
The rubber center is there to help reduce noise and act as a damper.
Like the rubber next to the teeth, it goes hard and disintegrates as well as coming loose letting the outer steel sprocket spin independently of the bearing,not a good situation.
These idler sprockets are no longer available from kawasaki and if the teeth of an affected sprocket are still good then replacing the failed rubber with aluminium is the only way to save them from the scrap bin.
With the solid center they will last for many thousand more miles.
If the camchain is not left to run slack or worn, the teeth should not wear any significant amount as they are not under driving load and then the only other limiting factor of these sprockets is the needle roller bearing which of course can easily be replaced.
Last edit: 21 Feb 2012 22:44 by zed1015.
  • notaduc
21 Feb 2012 22:46
#505564
I hadnt looked at them that closely, didnt realize that the teeth are independent of the hub.
  • notaduc
23 Feb 2012 00:54
#505826
Made a bunch of aluminum replacement tonight. Waiting on new bearings.
  • zed1015
  • zed1015's Avatar
23 Feb 2012 13:25
#505905
Where are you getting the replacement bearings from ?
I'm having difficulty finding replacements as they are an odd size(been scavenging good bearings from other sprockets and running low on them now)
I see Liska list replacement bearings for their sprockets but they don't state the dimensions so not sure if the outside diameters are the same as oem.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
23 Feb 2012 14:17 - 23 Feb 2012 14:18
#505923
very nice work there zed1015.
thanks for the description and pictures.
Last edit: 23 Feb 2012 14:18 by 531blackbanshee.
  • notaduc
23 Feb 2012 21:28
#506002
Fastenal has them. Their part no. is 4121959
I got them here though www.surfrainbow.com/Load_Product.aspx?Ca...214&ProductCode=7053
