Cam timing chain system.
  • notaduc
  • notaduc's Avatar Topic Author
19 Feb 2012 14:59
#505083
I have seen the Liska tensioner assy that replaces the stock plastic unit. Is the other plastic wheel typically replaced with a steel gear also?
1980 (mostly) KZ1000
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
Re: Cam timing chain system.
19 Feb 2012 19:38
#505133
i'd say its up to u. the stock rubber goes hard after many years of heat cycles. the rubber helps keep the top end quieter. i think the liska’s were designed for the racers. with no rubber on the components to flex, the cam timing is more accurate.
i beleive the liska's r cheaper .
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • racer54
  • racer54's Avatar
20 Feb 2012 01:16
#505188
[attachment:1]C:\fakepath\cam chain adjustment....jpg[/attachment]
There's a guy who sells these gears on E-Bay and I talked to him about them and he says you adjust the solid gears a little different to compensate for the rubber cushion effoct of the stockers. Here is a picture that he sent to show how to adjust them.
  • racer54
  • racer54's Avatar
20 Feb 2012 01:17 - 20 Feb 2012 01:21
#505189
Well...I'm having trouble getting picture to download. Basically he shows to pry on the cam sprocket bolt til you have about 1/8" slack on camchain near the top camchain idler gear. Not sure how you can adjust the slack but that's what he shows. Anyone here having problems posting today. This is the first time I have been able to post all day...
Last edit: 20 Feb 2012 01:21 by racer54.
  • Old Man Rock
  • Old Man Rock's Avatar
20 Feb 2012 08:22 - 20 Feb 2012 08:26
#505205
I used all components shown (APE) which are Liska for the most part...
As for adjustments, not sure what you're speaking of for the Top Idler, order a spacing block.
Had no issues with chain slack being off or too tight etc...
Liska Timing Components
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 20 Feb 2012 08:26 by Old Man Rock.
  • notaduc
20 Feb 2012 10:29
#505207
So the plastic wheel towards the bottom with no part number is the one I am wondering about. Is it typical to replace his with a metal toothed gear?
Oh, and do the APE spacer blocks shown reuse the oem dowels, or do they have some other alignment devise?
  • racer54
  • racer54's Avatar
20 Feb 2012 19:13
#505305
OMR...that's what I thought about the slack deal...that's just what the gut told me...could you tell any difference in noise with the liska gears...been told they are a little louder, which isn't a concern but curious...
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
20 Feb 2012 20:13
#505316
Racer, I've got the Liska gears in mine and can't tell if they are any more noisy or not over the RS34's clacking.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • racer54
  • racer54's Avatar
20 Feb 2012 21:37
#505342
I heard about that clacking noise but can't quite imagine what that sounds like.I will this summer as I plan on running a set but just curious if you can really tell the difference. Like a gear drive on a car...some don't like it but I like it...sounds like a blower drive coming at you.
  • Old Man Rock
20 Feb 2012 22:32
#505364
"could you tell any difference in noise with the liska gears...been told they are a little louder, which isn't a concern but curious..."
Yup... Definitely not louder as in clacking but more of a swishing/swirling sound... Hard to describe but a whizzing sound would be more like it... :blink:
Had me a tad buggered at first until I got out the stetho-scope and started analyzing the sound.
Well, in speaking with me amigos it made sense for the holes in the top idler would be catching more oil and throwing it all over the place inside the top end/valve cover.... All of which is good! ;) :woohoo: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • zed1015
  • zed1015's Avatar
20 Feb 2012 22:50 - 21 Feb 2012 07:42
#505370
To answer you original question.
There is no liska or other alternative to the other plastic wheel, It only acts as a guide and reduces chain slap and is otherwise under no load like the others and any wear on them is not as crucial as the others.
Last edit: 21 Feb 2012 07:42 by zed1015.
  • zed1015
  • zed1015's Avatar
20 Feb 2012 23:02
#505372
racer54 wrote: [attachment:1]C:\fakepath\cam chain adjustment....jpg[/attachment]
I've made my own for years now (see bottom of pic)
Adjust the camchain exactly the same as usual, Just enough to take up the slack without loading it and causing premature stretch.
Won't need re-adjusting for ages ;)
