Cost of machining a head
  • chrispysaki
  • chrispysaki's Avatar Topic Author
18 Feb 2012 00:08
#504787
Can anyone tell me what an average ballpark cost should be for having my kz750 (4) head machined down around .020-.025?
  • notaduc
  • notaduc's Avatar
Re: Cost of machining a head
18 Feb 2012 00:12
#504791
Whoa, why so much?
Think we charge $80
1980 (mostly) KZ1000
  • Kraz1
  • Kraz1's Avatar
18 Feb 2012 03:10
#504819
APE charges $30.00 to surface a Cylinder Head. LC350 is the Part Number/Labor Code.
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
18 Feb 2012 10:03
#504836
I would not expect to pay more than $75 to have it done. I paid $65 to have my turbocharged Z1 head resurfaced together with some cleanup on the intake mount area.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • LarryC
  • LarryC's Avatar
18 Feb 2012 11:01
#504839
Things like that are relevant to where you live . Anything from $35 to $80 would be realistic. Pull the exhaust studs out and the intake boots off first or they may charge you a bit extra for their time to do that....
Larry C.
  • APE Jay
  • APE Jay's Avatar
19 Feb 2012 01:38
#504980
Kraz1 wrote: APE charges $30.00 to surface a Cylinder Head. LC350 is the Part Number/Labor Code.
:cheer:
  • chrispysaki
20 Feb 2012 23:06
#505374
Thanks for the input! Anyone know of a reputable place in the Milwaukee, WI area to have this done?
  • TomW
  • TomW's Avatar
  • Keep the blue side up.
23 Feb 2012 18:55 - 23 Feb 2012 18:57
#505973
chrispysaki wrote: Thanks for the input! Anyone know of a reputable place in the Milwaukee, WI area to have this done?
There's a place called "The Shop" that works on vintage bikes. They are in Bay View. Call them and ask about machine shops. I have no experience with them. I do all my own work but my milling machine isn't large enough to mill a head. I sent my KZ1000 head to a shop in Fon Du Lac where my neighbor, who restores Austin Healys, has his machine work done. They did an excellent job. Beautiful finish and only took about .005" off and only charged me $30. PM me for more info.
Tom in West Bend
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Last edit: 23 Feb 2012 18:57 by TomW.
  • KZB2 650
  • KZB2 650's Avatar
28 Feb 2012 21:19
#506910
Jay if you happen to see this what does a .010, .020 or a .030 cut do for compression say in a stock kz750 or a kz650 with a 10.25 comp 700 kit?
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • KZB2 650
  • KZB2 650's Avatar
29 Feb 2012 17:58
#507046
Just pulled my kz650 head and I'm thinkin much more than .005 thou will touch the intake valve. I realize they'll remove the valves before cutting but Is this common for the valve to be sticking out of the head if you cut it .020 or .030?
1978 KZ650 b-2
  • lemo32
  • lemo32's Avatar
  • The Price of Cool aint cheap
29 Feb 2012 20:11
#507081
wouldnt removing that much metal alter cam timing?
1979 kz 1000 06 katana 750
  • DoubleDub
  • DoubleDub's Avatar
29 Feb 2012 21:00
#507093
KZB2 650 wrote: Just pulled my kz650 head and I'm thinkin much more than .005 thou will touch the intake valve. I realize they'll remove the valves before cutting but Is this common for the valve to be sticking out of the head if you cut it .020 or .030?
I'm sure it depends on the head and whether or not it has been surfaced in the past, but I had seen it stated that about .020" would not clip the valve.
I would think that you would be able to keep (roughly at worst) the same cam timing but would want to check your valve to piston clearances to be certain.
But this is all speculation as I have not done this yet myself. B)
