sanding cam bearings???
  • DoubleDub
  • DoubleDub's Avatar
Re: sanding cam bearings???
21 Jan 2012 14:36
#499227
I disagree.
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
21 Jan 2012 14:41
#499230
I was reading on a car forum about the same subject. A well known racer/engine builder was asked how he assembled a bottom end and he stated he used scotch brite on the bearings to scuffthem up before putting assembly lube on.
A youngster jumped in the discussion and told everyone that was the wrong way to do it and it would ruin the bearings and yada yada.....
Another member asked the youngster how many National Titles he had under his belt. No responce.
There is one thing going for us on this subject. These old engines are about bullet proof and most builders are are not going to a limit where the life of the engine depends on sanding/scuffing up bearings would means life or death for the engines.
On subjects such as this,I listen to the most experienced.
I have a coffe can of cam bearings and when I assemble a engine and if I don't have the right shims to bring the valve clearance into adjustment,I go through all my cam bearings and measure them and install the ones that will give me the clearance to bring my valves into the right tolerances.
That statement should bring on a fire storm. :whistle:
21 Jan 2012 15:29 - 21 Jan 2012 15:32
#499256
roy-b-boy-b wrote: I was reading on a car forum about the same subject. A well known racer/engine builder was asked how he assembled a bottom end and he stated he used scotch brite on the bearings to scuffthem up before putting assembly lube on.
Damned right it will; everyone knows you should keep old cam bearings in an empty peanut butter jar - not a coffee can. :)
Last edit: 21 Jan 2012 15:32 by 650ed.
  • z1kzonly
  • z1kzonly's Avatar
21 Jan 2012 16:00
#499260
You don't sand! You rub them with fine grey scotch pad.
It's a babbit style coating, just like car engine rod bearings.
I never bought a new bearing in 35 years. 3/4's of the time I never measured them with plasti-gauge
either. Put em together with a quality moly-bedum sulfide, break in grease. 1st 9 grand shift will let you know if there good! :woohoo:
  • andy9802gt
  • andy9802gt's Avatar
  • If it tastes that good, eat it yourself.
21 Jan 2012 19:20
#499287
I like the look of the 8" over. I wish it was a shock arm so the ride would be more comfortable and admittedly I have some traction issues due to not being able to find a sticky tire to fit on the stock 16" wheel. At some point I'm going to monoshock it and I'm thinking about taking a little of the stretch out when I do to help with that. If you ever come through fort Wayne on a wednesday night stop at Quaker steak and lube for bike night.
'78 KZ1075 LTD
stage 1 head by Larry Cavanaugh
race built crank by John Pearson
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
proving once again that age and treachery is better than youth and enthusiasm
  • Powerstroke_fan
  • Powerstroke_fan's Avatar Topic Author
21 Jan 2012 19:38
#499289
ya i will iam usally in town early in the mornings. but if i get time i might cruise up there this summer.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • LarryC
  • LarryC's Avatar
21 Jan 2012 21:19
#499308
steell wrote: Why does it have to be a pissing contest? I have my way and you have your way, big deal, don't seem like something to get upset about. It would be a boring world if everyone thought the same.
More than one way to skin a cat.
I didn`t see that post.
As with all things related to building engines, opinions will vary. Sometimes, it's just not worth the bandwidth to debate the issue. The way I do that particular method has never failed in 30 years. I think I would call it proven in the real world. Been run at Bonneville, drag strips, Willow Springs...... Not to mention 10s of 1000s of street miles..... I'll stick with it
Larry C.
  • andy9802gt
21 Jan 2012 22:59
#499327
I've got around 2500 of those 10's of thousands and have no signs of an issue. That's enough for me to believe it can be done.
'78 KZ1075 LTD
Mikuni rs34's
k410 cams
back cut tranny
8" over D&G swinger
  • steell
  • steell's Avatar
22 Jan 2012 00:40
#499354
DoubleDub wrote: I disagree.
Yeah, but everyone knows how you are :evil:
  • DoubleDub
22 Jan 2012 01:55
#499367
:laugh:
