- Thank you received: 114
1075 specs....what do ya got?
- racer54
24 May 2006 16:56 #49827
by racer54
1075 specs....what do ya got? was created by racer54
I'm curious what you have in your 1075 and what parts you used to get there. Besides the 1075 kit, what cams, carbs, head work, etc. and what level performance are you at...prefer e.t. and mph if you have them. How much does you and your bike weigh to get that performance.
Mine...it's a 1075, 29 smoothbores, V&H street header with otherwise stock motor. MK11 trans. and welded crank. Stock gearing with a weight about 670 lbs. Best I've done is about 11.4's with slick and 11.6's with a 130 street tire in a stock wheelbase chassis. Thinking of putting in a set of GPZ cams for a little more power.
What's in yours?
Post edited by: racer54, at: 2006/05/24 22:46
What's in yours?
- cary
26 May 2006 09:57 #50258
by cary
Replied by cary on topic 1075 specs....what do ya got?
670 lbs? ...hope that's you AND the bike.
- racer54
26 May 2006 14:56 #50311
by racer54
Replied by racer54 on topic 1075 specs....what do ya got?
Nope...just me! Just kidding. Figure 500# for the bike...170# for the dead weight.
Post edited by: racer54, at: 2006/05/26 18:02
- fastestz1
- Thank you received: 3
26 May 2006 18:25 #50358
by fastestz1
Replied by fastestz1 on topic 1075 specs....what do ya got?
i have one carburated bike its a 900 with a 1075kit 10.25.1 compression,37.5mm / 31mm valves,.385 z2 cams,lots of port/polish work, ,34mm flatslides,pingel pet cock, dyna coils/ignition,vance+hines pro pipe with competition baffle,this bike is lowered 2in front 3in rear,18front 47 rear sprockets,this bike makes 125rwhp on 2 different dyno's. its got a few other old time tricks that really help it hustle.when i had this engine built i hated it! i thought it was so slow compared to my turbo bikes but once i calmed down and took sum time to really learn how to ride it i fell in luv with it!
Post edited by: fastestz1, at: 2006/05/26 21:29
- sbjones
26 May 2006 19:56 #50366
by sbjones
Replied by sbjones on topic 1075 specs....what do ya got?
i am building my bike as of right now. i will be doing the 77 1000---ape kit 1075--ape410 cams---34mm flat sides---1mm over valves---ported and polished head (home done) welded 900 crank(possobly knifed edged, not sure yet)
i want an engine that will rev fast and strong. i am hoping around 120-130 hp, but we shall see.
since i want a light bike, i am putting this in a '78 kz650 frame. with 2004 gixxer rear end and gixxer 2001 front end complete. all this with the stock (old kz) looks.
also at this time i am doing a solo seat set up. this is going to be a long project, but i want to do it myself as much as i can.
have fun wrenching guys, i will keep this site up to date with it all.
- APE Jay
- Visitor
26 May 2006 22:28 #50390
by APE Jay
Replied by APE Jay on topic 1075 specs....what do ya got?
Post your power when it is done. You certainly picked the best cam for a 1075.
Jay
Jay
- sbjones
27 May 2006 01:20 #50404
by sbjones
ape jay, what kind of hp you think that i will see with this set up?
the 1075 will have the 10.25:1 comp.
let me know
let me know
- sbjones
27 May 2006 01:40 #50405
by sbjones
fastest---what type of pingel fuel pet cock are you using? dual or single outlet please.
thanksB)
thanksB)
- roy-b-boy-b
- Thank you received: 103
27 May 2006 04:29 #50409
by roy-b-boy-b
Replied by roy-b-boy-b on topic 1075 specs....what do ya got?
My "79" LTD has a 1075 kit with Andrews cams.I forgot the specs. I was running "29's" but now am running CV's.
Lucky Nowles built my engine. He has been wrenching on Kawasakis before the Z1 came out.
I don't know how much HP i have but i can lay down a black mark over 300 ft. My best is 317 ft.
Wired George said,"You can't do that." OH yes i can!
It will hang with a crotch rocket weel into fifth gear.
I call it my ye-ha bike. Roy
A member here, Sonny can build you a killer engine. He works at Phillips Pro Cycle in Carbondale,Ill. I wish he would post a pic of his bike. Roy
Post edited by: roy-b-boy-b, at: 2006/05/27 07:32
- fastestz1
27 May 2006 04:30 #50410
by fastestz1
dual outlet pingel,i got it from jeff at z1 enterprise he gave me a better price than pingel themselves.
- sbjones
29 May 2006 17:11 #50795
by sbjones
roy-b,what type of cv's are you running? are they 34 mikuni's if so how are they for you? because i have a set and wanted to run these, but i think that i want more power with the 34rs's
let me know please.
let me know please.
- nads.com
- Thank you received: 20
29 May 2006 21:54 #50856
by nads.com
Replied by nads.com on topic 1075 specs....what do ya got?
With 10-1 compression and 1075, I cant see for the life of me, spinning the tire for 300ft on dry pavement made in america, without holding the front brake. Ive got a 1015 motor and dont know this lucky person that instilled magic into your motor, but my bike does not do that att all and it can hang with a rocket any day. What do you weigh 20lbs? Im not making fun of your post at all but im not sure what i missed when i put my motor together, a couple of pistons maybe? Because man, the real secrets to making power are not handed down to the average bear and noone ive read on has told me what really makes these motors go. I feel like ive been decieved.
