is it called output shaft seal?
  • ramtough_63
  • ramtough_63's Avatar Topic Author
07 Jan 2012 12:44
#496904
I have always had a leak by the front sprocket whe I remover the cover
and sprocket I noticed the seal is cut. going to order one just want to
make sure I am calling it the right thing.
also I noticed Z1 E has an O-ring that goes behind the front sprocket??
is this in addition to or in place of or...
Attachment zoutputshaft.JPG not found
any problems with replacing this seal?
Is it straight forward just remove the seal install now one
or is more teardown required
I see Z1E is out of the seat sets
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • MFolks
  • MFolks's Avatar
Re: is it called output shaft seal?
07 Jan 2012 17:00
#496928
While your ordering seals, get a new one for the clutch pushrod. Remove the transmission cover(Kawasaki calls it the 'mission cover) and with it removed, use a large socket and hammer to drive them out.
When ready to install the new seals, put some light grease for lubrication on the seal edges and drive them in place. Wrap some tape around the sharp splines to protect the new seals before installing the cover. Masking or plastic electrical tape will do fine.
  • zed1015
  • zed1015's Avatar
07 Jan 2012 17:06 - 07 Jan 2012 17:16
#496929
Yes! it's a straightforward remove and replace.
Slide out the spacer sleeve that sits in the seal behind the sprocket and then there's plenty of room to get a hook in to pull out the seal.
There is no need to remove the transmission cover, the seals come out easily.
The 'O' ring is additional to the seal and goes on the output shaft.
It seals against oil seeping out between the sleeve and the output shaft.(The sleeve has a slight tapered recess that the 'O' ring sits in).
In this instance there is no need to mask the splines on the output shaft as there is a lot of clearance between it and the seal as it is the sleeve that runs in the seal.
Last edit: 07 Jan 2012 17:16 by zed1015.
  • ramtough_63
07 Jan 2012 17:17
#496930
thanks guys its alot of help. as you know my bike is about 70 miles from where I live and i cant run out and look at stuff and have to order stuff and take it with me. it's not ideal but its better than the alternitive.
my girl says to bring it home and put it in the house til i get it done thats a thought
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • zed1015
  • zed1015's Avatar
07 Jan 2012 22:30
#496981
DO IT.
It'll be much nicer to look at than the telly :) .
  • ramtough_63
07 Jan 2012 23:32
#496993
I am seriously considering it. there is no way driving an hour and 20 minutes to work on it is gonna get anything accomplished this winter. (if it ever turns winter) big plans are hard to do when i keep moving it to a garage further away each time.
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • ramtough_63
11 Jan 2012 23:28
#497638
this set is from Z1E does it have the sealI need in it?
Attachment z1eoilssealkit.jpg not found
Schnitz racing calls it a counershaft seal is that the same thing?
Attachment img_var_trans.jpg not found
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
12 Jan 2012 00:14
#497649
Many aftermarket parts suppliers include a reference to the original manufacturer's part number, which should confirm intended application of the new part.
Could determine the KHI part number from kawasaki.com.
If needed, here's a link for help with navigating the kawasaki.com site and finding information.
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=376734
Good Fortune! :)
  • ramtough_63
12 Jan 2012 00:33
#497656
Patton wrote: Many aftermarket parts suppliers include a reference to the original manufacturer's part number, which should confirm intended application of the new part.
Good Fortune! :)
Thanks patton got the part number and it is part of the kit
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • zed1015
  • zed1015's Avatar
12 Jan 2012 07:19
#497696
ramtough_63 wrote: this set is from Z1E does it have the sealI need in it?
Yes and Yes :) ,
  • jydog
  • jydog's Avatar
12 Jan 2012 07:28
#497697
Seals are back in stock at Z1E
81 KZ1000 LTD
Griffin GA
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
12 Jan 2012 12:28
#497741
not trying to be a bad influence :whistle: ,
but
here is my shovelhead,
in my dining room :cheer: .
and here is my dad's knucklehead,
also,in the dining room. :laugh: .
i think motorcycles can be interior design elements themselves. :silly: .
