4 into 2 Vs 4 into 1
  • SATSFYD
  • SATSFYD's Avatar Topic Author
23 Dec 2011 06:02
#494418
What is the different from the 4 into 2 exhaust vs the 4 into 1? Does it change the torque power curve? Or do people do it for the weight saving?
Re: 4 into 2 Vs 4 into 1
23 Dec 2011 07:05
#494421
SATSFYD wrote: What is the different from the 4 into 2 exhaust vs the 4 into 1? Does it change the torque power curve? Or do people do it for the weight saving?
And some folks prefer the more "balanced" appearance provided with a muffler on each side.
Good Fortune! :)
  • 750steve
  • 750steve's Avatar
23 Dec 2011 09:52
#494427
The theory is that a 4 into 1 will give more top end power where the 4 into 2 will give more midrange........in saying that i highly doubt you'd notice the difference & different pipes will give different dyno curves so IMO its not worth worrying about..........go with what you like the look of or ties in with your bike's style.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • bluej58
  • bluej58's Avatar
23 Dec 2011 10:32
#494430
[quote="Patton"
Good Fortune! :)[/quote]
That would be me, plus You don't have to lose the center stand.
JD
78 KZ1000 A2A
23 Dec 2011 10:56
#494433
Good Fortune! :)
+1
  • H1Vindicator
  • H1Vindicator's Avatar
23 Dec 2011 11:33 - 22 Jan 2013 00:41
#494434
Last edit: 22 Jan 2013 00:41 by H1Vindicator.
  • ramtough_63
  • ramtough_63's Avatar
23 Dec 2011 11:48
#494437
internal comustion engines are essentialyy an air pump. the freeer the air gets in and gets out the more horsepower you produce. exhaust is only one componet and usually the cheapest mod. if you put bigger carbs, valves, port the heads coming in you have to be able to get it out.
with that said the back pressure from the pipes (ie diamiter of pipe bends in tubing size and shape of collecter)tune the torque curve and over all over hp @ a given RPM
Generally speaking you will notice a modest gain in torque and performance with a 4 into 1 swap. but this is only 1 component in increasing overall performance
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • loudhvx
  • loudhvx's Avatar
23 Dec 2011 16:03 - 23 Dec 2011 16:05
#494456
I think dual is quieter from a noise pollution testing standpoint. If you can scatter sound in more directions, any one direction will be quieter. That probably weighs in on factories using dual, in addition to the other factors.
Weight is a pretty huge factor, though, when you campare a full factory chrome dual to an aluminum canister Kerker.
Last edit: 23 Dec 2011 16:05 by loudhvx.
  • Mookachacka
  • Mookachacka's Avatar
23 Dec 2011 17:36
#494467
What about a 4-2-1 compared to a 4-2, does the 4-2 still give more midrange or are they more or less equall?
23 Dec 2011 17:54
#494469
Mookachacka wrote: What about a 4-2-1 compared to a 4-2, does the 4-2 still give more midrange or are they more or less equall?
Interesting discussion. I would love to see someone put a properly tuned totally stock KZ on a dyno then swap out only the exhaust and re-tune the bike for the new exhaust and dyno it. I think it would be great to see a true apples to apples comparison of the two powerbands - one with stock pipes and one with 4>1 without other mods (other than properly tuning the bike for the pipe) as this would reveal the strengths and weaknesses of each system. Ed
  • ramtough_63
23 Dec 2011 18:28
#494471
that would be great. I know on the comarisons I have seen on newer bikes the 4 into one is a couple horsepower throught out the rpm range over stock and a few less in the midrange with a more exotic 4 2 1 or tri y designs or whatever they call em
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • 750steve
  • 750steve's Avatar
23 Dec 2011 18:47 - 23 Dec 2011 18:51
#494473
loudhvx wrote: I think dual is quieter from a noise pollution testing standpoint. If you can scatter sound in more directions, any one direction will be quieter. That probably weighs in on factories using dual, in addition to the other factors.
Thats very true Lou, at our trackdays we are noise tested over here & its very hard to get a true reading of a dual exhaust bike according to noise testers. The rules state that a bike is tested at a given RPM (7000 for 600's & 5500 for 1000's) at a 45 degree angle, 50cm away from the exhaust exit height. They cant test the dual exit's correctly especially if thay are either side of the swingarm. I've seen & heard many times of a big bike passing the noise test & then being louder on track than a single pipe bike putting out similar DB. They have now started to introduce 'drive by' testing to read differently.
ramtough_63 wrote: that would be great. I know on the comarisons I have seen on newer bikes the 4 into one is a couple horsepower throught out the rpm range over stock and a few less in the midrange with a more exotic 4 2 1 or tri y designs or whatever they call em
Also true. I'm involved in the road racing here in Northern Ireland & i've seen dyno sheets to prove that a 4-1 has slightly more top end power on a modern sports bike than a 4-2-1, or a 4-2. Im sayig that some of the 4-1-2 systems work well on a GSXR1000 like the Leo Vinci
You commented about header pipe shape.......Micron used to do a 'Serpent' header pipe that was supposed to improve torque but i didn't ever see data to prove that, if it worked they probably wouldnt have went out of business & everyone else would have copied i reckon. The 1st curve on the headers looked like a cobra ready to attack
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 23 Dec 2011 18:51 by 750steve.
