oil behind dymo cover
  • locolobo
  • locolobo's Avatar Topic Author
09 Dec 2011 19:19
#492407
should there be oil in the stator/alternator housing when you remove cover>?or is mine a dry stator?
1983 kaw 750 belt k1 ltd
locolobo
  • Link14
  • Link14's Avatar
Re: oil behind dymo cover
09 Dec 2011 20:06
#492413
I remember the manual for my 1982 KZ750-H3 Ltd to put a pan under the stator housing when you pulled it to catch a little oil that would come out.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
09 Dec 2011 21:13
#492417
I would imagine so. On Z1s and KZs, there is oil there.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • MFolks
  • MFolks's Avatar
09 Dec 2011 21:18
#492418
I believe the oil is for the starter clutch and alternator cooling.
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
09 Dec 2011 21:52
#492424
Oil is normal behind that cover.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • locolobo
11 Dec 2011 19:03
#492678
thanks guys.....if the igniter goes the bike wont start right>?yea i knw dumb question but i dont have but three things left to try and i cant put meters on anything coz i cant get it started...too much fuel in float bowl and flooding itself out....hell i dont knw....ready to give up on this ...ran great for 2 yrs go to one bike rally and it runs or dont run at all....thanks....doug
locolobo
  • MFolks
  • MFolks's Avatar
11 Dec 2011 19:23
#492681
The engine might crank(turn over), but with no spark from the ignition, it won't run.
The following user(s) said Thank You: locolobo
