- Thank you received: 1
One cylinder not cutting out
- KZCool
1976 KZ750 hardtail
- TeK9iNe
- What did you do!?!
- Thank you received: 28
This is generally a good indication that there is a clog in the pilot mixture circuit (either in the carb itself or the jet), or an air leak is present.KZCool wrote: the piolet screw has no affect no matter how far I turn it out or in.
Turning the mixture screw closed should cause the engine to stumble, and also at some number of turns out.
A significant air leak can prevent proper vacuum from picking up enough pilot mixture - hence no start.
Could be that your idle input (thumbscrew) is not set correctly as well - like too little, or far too much idle to compensate for another issue.
Many different things can affect proper carburetion - best to pull them, clean them like new, confirm that cleaner will blast properly throughout the carb thru holes into its bore, set the slide gaps as close as possibly the same and set base idle opening to about 1mm. Make sure to seal everything up good when reassembling.
Take car to make sure everything is set to baseline specs as per manual. Including timing and such. - basic maintenence.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- KZCool
1976 KZ750 hardtail
- KZCool
1976 KZ750 hardtail
- Thank you received: 2098
KZCool wrote: ...the one cylinder still wont fire. It wont fire even when I open the throttle. It has spark...bike does die when I pull the cap off of the sparkplug even though that cylinder isnt firing. Tinking about just getting a new coil. Is the 3 ohm Dyna ok to use with a Dyna S ignition?
Plug wire might be shorting to engine or chassis (typically happens with old hard cracked worn-out spark plug wires). Z1E also list the Dyna plug wires with caps already built in. I have enjoyed Dyna's solid copper core versions for many years.
Valve clearances within specs?
Would test compression both wet and dry, to compare.
Green 3 ohm Dyna coil is fine with Dyna-S ignition.
KZCool wrote: ... one cylinder still wont fire... bike does die when I pull the cap off of the sparkplug even though that cylinder isnt firing....
Engine dies when the secondary loop is interrupted, because neither plug fires under such condition.
If tested with a known good spark plug attached to the cap and plug's base grounded against engine head, and spinning or kicking the engine over with the ignition switched ON -- are sparks visibly observed at tip of the plug?
In other words, is it for sure that a good plug is firing, as contrasted to a cylinder that isn't firing?
(Sometimes a cylinder won't fire despite plenty of plug sparking.)
Or an internally shorted spark plug might be allowing conductivity through the secondary loop even though the plug itself isn't sparking.
Perhaps could elaborate about the Dyna-S on a twin.KZCool wrote: ...76 kz750 twin...dyna S ignition....
- KZCool
1976 KZ750 hardtail
