One cylinder not cutting out
15 Nov 2011 14:42 #488605 by KZCool
One cylinder not cutting out was created by KZCool
So I recently took my engine out of my 76 kz750 twin due to my kickstart failing, and after fixing that problem and getting it back in only one of my cylinders is firing consistantly. The other will pop and fire and cut out and back fire and all that jazz. If I open the throttle a little it seems to not be nearly as bad. Ive taken the carbs off cleaned them, checked the timing, recently checked and regapped the valves, checked the voltage comming off my dyna S ignition and it was fine, and the only thing I can come up with is that the coil is bad. It's a wasted spark system though and the other cylinder fires just fine. Anyone know if it is possible that the coil could be bad? Its the original coil too.
1976 KZ750 hardtail
15 Nov 2011 15:38 #488614 by Patton
Replied by Patton on topic One cylinder not cutting out
KZCool wrote: So I recently took my engine out of my 76 kz750 twin due to my kickstart failing, and after fixing that problem and getting it back in only one of my cylinders is firing consistantly. The other will pop and fire and cut out and back fire and all that jazz. If I open the throttle a little it seems to not be nearly as bad. Ive taken the carbs off cleaned them, checked the timing, recently checked and regapped the valves, checked the voltage comming off my dyna S ignition and it was fine, and the only thing I can come up with is that the coil is bad. It's a wasted spark system though and the other cylinder fires just fine. Anyone know if it is possible that the coil could be bad? Its the original coil too.
Possible erratic spark, perhaps from a bad plug wire leaking voltage to the engine head.
Could remove both plugs, tape them together (or hold both against the engine head) and assess spark quality while spinning the engine over.
Good Fortune! :)
15 Nov 2011 15:42 #488615 by Patton
15 Nov 2011 16:04 #488618 by MFolks
Replied by MFolks on topic One cylinder not cutting out
I'd replace both sparkplug caps as they contain a 5000 ohm resistor that over time can go bad, making for erratic spark at the plug. Tried another brand of sparkplug? I've found that some of the US made NGK's are not as good as the ones made in Japan.
15 Nov 2011 21:43 #488680 by KZCool
Replied by KZCool on topic One cylinder not cutting out
MFolks wrote: I'd replace both sparkplug caps as they contain a 5000 ohm resistor that over time can go bad, making for erratic spark at the plug. Tried another brand of sparkplug? I've found that some of the US made NGK's are not as good as the ones made in Japan.
Thanks a ton for the advice. sure enough I checked the resistance of one of the caps and it was 5 something kilo-ohms and the other was infinite, just ordered some new ones from Z1 so I should be riding in 2 days. Thanks again.
1976 KZ750 hardtail
16 Nov 2011 00:31 #488703 by MFolks
It's a simple test & cheap repair when you get a miss like this. I always check the sparkplug caps before tearing into the carbs.
These 4 strokes need but four things to run:
1.Compression
2.Clean air
3.Fuel
4.Spark
If any of the above are not there, the engine will not run.
20 Nov 2011 19:22 #489368 by KZCool
I just got my caps from Z1 and the same thing is happening. I dont think its the carbs but it might be. The one cylinder runs great all the way down to below 1K so it wouldnt be the timing thats off or it wouldn't run that well at that low of an RPM. and the other doesnt fire at all untill I rev it a little. The piolet screw had no affect on it, but when I started it with the "choke" or fuel plunger open, both cylinders fired just fine.
1976 KZ750 hardtail
20 Nov 2011 19:29 #489369 by baldy110
Replied by baldy110 on topic One cylinder not cutting out
Did the engine run fine before fixing the kickstarter, if so I would say it has to do with something related to repair.
20 Nov 2011 20:07 #489376 by Kapahulu
Replied by Kapahulu on topic One cylinder not cutting out
If you haven't already done so, make sure the connection of the plug wire to the coil is good.
Yesterday my dog ate one of my plug wires. I replaced the wire (dyna coil) and the bike was running cruddy at idle. I thought something had clogged the pilot jets and I cleaned the carbs. That didn't fix the problem and then I realized the connection from the plug wire to the coil was not 100%. With that fixed, the KZ runs like a champ - even better than before with the freshly cleaned idle circuits.
2strokeworld.com
21 Nov 2011 13:33 #489480 by KZCool
Ill look into the leads. The spark plug wires come straight out of the coil though so im not sure what to look for. And it did run fine before but the only thing i had to do in the end was replace the retaining ring on the kick shaft. Didnt need to take my eninge out after all :pinch: . What doesnt make since is if its a spark problem, why would it run better with the choke on? Just strange.
1976 KZ750 hardtail
21 Nov 2011 13:43 #489481 by Patton
Patton wrote: ...Could remove both plugs, tape them together (or hold both against the engine head) and assess spark quality while spinning the engine over....
Do both plugs show fat blue sparks?
Good Fortune! :)
21 Nov 2011 13:48 #489482 by Patton
Given acceptable compression, correct valve clearances, and a healthy properly timed spark, could then look to an issue in the carb pilot circuit (perhaps the passageways are still not yet sufficiently clean).
Good Fortune! :)
