Problem engaging clutch
  • Archiddeon
  • Archiddeon's Avatar Topic Author
14 Oct 2011 02:24
#483093
Trying to restore my 1983 GPZ 550, finally got the engine running (yay!) so now onto other things ... the clutch lever is very loose and didn't feel like it engaged when pulled (no resistance). Maxxing out the adjustment had no effect.
I pulled off the sprocket cover on the left side, disassembled and greased the push rod actuator (the little cylinder mounted on the plate of three ball bearings that the clutch cable pulls on), reassembled ... no dice, same thing.
Ok, maybe the clutch is jammed on the other end (This bike hadn't run for 2 years, so who knows). Drain the oil and pull off the clutch cover on the right side ... all looks good. Very little wear is apparent, no burning smell, all springs present and accounted for, the little steel ball between the push rod and that little end piece is still there ... hrmmm. Reassemble and try again ... still no clutch engagement.
Remove the sprocket cover, put a small glob of grease on the left end of the push rod and replace the cover ... pull the clutch a few times (it doesn't spring back, so has to be pushed back) and off with the cover again. The glob is untouched ... so the end of the push rod is not even touching the inside of the actuator.
Sooo ... any suggestions? Is there some way to adjust the push rod or the actuator? Is there something I could test to further pinpoint the problem?
Thanks!
1983 GPz 550
1985 Honda CH150 Scooter
1995 Suzuki GS500E
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
Re: Problem engaging clutch
14 Oct 2011 02:34
#483098
Most of our clutch cables adjust tighter as we "unscrew" the adjustment mechanism. Are you turning this the correct way? I'm not sure about the 550, but my 750 has a pushrod adjustment on the engine sprocket cover. There is a small rectangular piece held on by 2 screws. If you remove this there is an adjustment nut. Again, I'm not sure if your bike had this, but your repair manual would be able to help you there as well. :)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
  • Archiddeon
14 Oct 2011 02:47
#483100
Yeah yeah yeah! Thanks, Clutch :) ... ironic? :P
I sat there for a while trying to figure out which way to lengthen or shorten the chain. Didn't know what the little screw head under the sprocket cover plate was for though! I'm certain this is it. Will try it out tomorrow and report the results :)
1983 GPz 550
1995 Suzuki GS500E
  • clutch
  • clutch's Avatar
14 Oct 2011 02:49
#483101
Sounds like you figured out what you need. Make sure you check the specs in your manual for proper pushrod adjustment. Glad I could help :)
Wish List:
  • Old Man Rock
  • Old Man Rock's Avatar
14 Oct 2011 09:11
#483125
In case you need...
kz550-service-manual
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
The following user(s) said Thank You: clb3carl
  • TexasKZ
  • TexasKZ's Avatar
14 Oct 2011 11:25
#483146
FYI - Pulling the lever DIS-engages the clutch and releasing the lever ENgages it.
  • Archiddeon
16 Oct 2011 16:45 - 16 Oct 2011 16:45
#483549
Hehe, thanks Texas :)
Problem has been resolved. On the left side of the bike, on the sprocket cover was the rectangular cover plate secured by two bolts. Underneath was the clutch adjustment screw. Set it according to the manual (tight then back off 1/2 turn) ... noting that clockwise LOOSENS and counter-clockwise TIGHTENS. Adjusted the cable free play a bit and now the clutch is good to go :D
Thank-you :laugh:
1983 GPz 550
1995 Suzuki GS500E
Last edit: 16 Oct 2011 16:45 by Archiddeon.
