Kickstart Not returning to original Position
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Kickstart Not returning to original Position
05 Mar 2020 09:58
#820339
The spring needs to be under tension when at rest. It's easy to get it in the wrong place.
  • chochbag
  • chochbag's Avatar
07 Mar 2020 09:39
#820477
Yeah, I soaked it, nothing...
  • chochbag
  • chochbag's Avatar
07 Mar 2020 09:44
#820479
That’s what I was thinking, but the manual doesn’t say exactly how to achieve that tension. I put the one end in the crankcase hole, and with needle nose pliers, rotate the other end about half a turn counterclockwise under the shaft before the other end seats on the shaft. So that should be about half a turn’s worth of tension. Are you supposed to muscle the spring the other way over the top of the shaft instead, or somehow make another rotation before seating the spring? I just don’t see a way, unless I’m missing something...
  • ChrisMH
  • ChrisMH's Avatar
Yesterday 11:54
#926200
Yet another resurrection.  My KZ750 is doing exactly the same thing.  Did you ever figure yours out?
  • Nerdy
  • Nerdy's Avatar
Yesterday 12:18
#926202
There is no real reason to resurrect old threads like this. You might as well create a new one with your specific details.
The last post was over six years ago; that user (chochbag) has a total of three posts and hasn't logged in to KZR since November 2022. It's pretty safe to say you're not going to get a response.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • TexasKZ
  • TexasKZ's Avatar
Yesterday 12:21
#926203
See the post by Wiredgeorge in this thread.
kzrider.com/forum/2-engine/206043-kz-750-twin-kickstart
  • Romanewark
  • Romanewark's Avatar
Yesterday 15:48
#926207
Well Nerdy with much respect there is a real reason for resurrecting this old post, and that is because the kickstarter still doesn’t return to its parked position. And isn’t helping each other out the whole point of this chat?  Chris MH, no l haven’t figured this out yet and have been relying on the electric start up until now. The original guys who posted this problem are all gone but never provided any solution. I’m glad you reopened the thread maybe someone can help. I haven’t been able to spend any time on the bike recently unfortunately. Later this summer I’m going to get back into it. I will definitely let you know what I find out. Good riding brother.
