No top end
  • moke
  • moke's Avatar Topic Author
  • Been there, done that, still doing it!
No top end
05 Oct 2011 17:58
#481548
Hi I came across a cheap 80 KZ250ltd and it has a few quirks. It ran great for a week then I let the bike sit a couple weeks, now it doesn't like to rev up towards 10k like it used to and has less and less top end as you go through the gears. Ive cleaned out the carbs (almost spotless) plugs a little rich but not too bad, no vacuum leaks that i can find. A buddy of mine said to check the spark advancer? Any input from the wise buke gurus?
It's not what you ride it's that you ride!
1980 Kawasaki KZ250 LTD (current project)
1978 Honda CB400
1987 Honda Elite 50 (speed project)
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: No top end
05 Oct 2011 18:20 - 05 Oct 2011 18:24
#481554
Spark advance would be a good place to start.
We always like pics of your bike.
Also it would help if you would add some details to your profile.
Why don't you list the year and model of your ride in the signature line, it's part of your profile.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Last edit: 05 Oct 2011 18:24 by KZQ.
  • moke
Re: No top end
06 Oct 2011 01:40
#481633
Tried playing with the carb, checked valve clearance and whatnot and took it for a ride. Noticed now that while at higher rpm (6-8k) it feels as if the engine is "catching up" can hear and feel it pull harder in this range then completely dies off if I shift into 4th or try to get it past 8k rpm. Ill get some pics up if I can in the afternoon tomorrow
1978 Honda CB400
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
Re: No top end
06 Oct 2011 05:16 - 06 Oct 2011 05:16
#481650
moke wrote: plugs a little rich but not too bad
Running rich can cause hesitation in the top end.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Last edit: 06 Oct 2011 05:16 by clutch.
  • Motor Head
  • Motor Head's Avatar
Re: No top end
06 Oct 2011 09:49
#481669
Have you been into the Ignition cover on the side of the head? This is where the points and condenser live as well as the advancer your friend was talking about. Do you have a service manual? It will explain how to check the point gap, the Ignition timing, and servicing the advancer assy. Probably needs the points/ condenser kit, and clean/ lube the advancer, proper point gap, and timing. Then It will run like a 250 again.
Have you checked to see if the Air Filter is clean and not blocked?
Re: No top end
06 Oct 2011 11:24
#481686
Perhaps the advancer looks like this:
Good Fortune! :)
  • moke
Re: No top end
06 Oct 2011 12:02
#481693
forunately my advancer doesnt look quite like that! I have a service manual that came with the bike is anyone aware of a good points condenser kit these look a little old, as in 1980 ;) . Or would a kit meant for the same year kz100 work due to my engine being 1/4 of that?
1978 Honda CB400
  • Motor Head
Re: No top end
06 Oct 2011 12:22
#481695
www.z1enterprises.com/Ignition-Points--K...Z200-KZ250-4441.aspx
Z1 has the points, but I don't see a condenser. Email, or call them.
Re: No top end
06 Oct 2011 12:46
#481699
moke wrote: Tried playing with the carb, checked valve clearance and whatnot and took it for a ride. Noticed now that while at higher rpm (6-8k) it feels as if the engine is "catching up" can hear and feel it pull harder in this range then completely dies off if I shift into 4th or try to get it past 8k rpm. Ill get some pics up if I can in the afternoon tomorrow
Perhaps fuel starvation due to obstructed tank venting.
If not already done, could test-run with the fuel tank cap ajar (which assures venting).
Good Fortune! :)
  • moke
Re: No top end
06 Oct 2011 18:38
#481745
ok found some history on the bike the two weeks where I didn't ride it found out my friend had used it and laid it down on the gravel and knocked the contact cover and assembly loose he screwed it in and it ran ok according to him. Played with the plate some and come out that the timing was veryyyyy retarded, backfiring no power so i advanced it slightly and it works better now to figure out how to time it with the service manual
1978 Honda CB400
  • clutch
  • clutch's Avatar
Re: No top end
06 Oct 2011 20:05
#481769
moke wrote: ok found some history on the bike the two weeks where I didn't ride it found out my friend had used it and laid it down on the gravel and knocked the contact cover and assembly loose he screwed it in and it ran ok according to him. Played with the plate some and come out that the timing was veryyyyy retarded, backfiring no power so i advanced it slightly and it works better now to figure out how to time it with the service manual
That should be an easy fix, and doesn't require you buying new parts. You will need a timing light to do it right. If you don't have one, I just bought a basic one on ebay a few weeks ago for about $20. It doesn't have all the fancy gauges built in, but it does what you need it to do.
~Clutch :)
Wish List:
  • Motor Head
Re: No top end
06 Oct 2011 23:37
#481815
set the Gap of the points, then time the spark firing. If you have no timing light, you can do it Statically. Either a test light, or Volt Ohm Meter, you can even lay the plug against the head. Turn the motor so the "F" mark lines up, then turn the points plate so the points are closed, then back to where they just open. You can even see the spark between the point contacts.
