No top end
- moke
- Been there, done that, still doing it!
Re: No top end
09 Oct 2011 00:12
went and redid the timing (static) it runs better overall but wont rev past 7.5k in gear. Ive noticed when i rev the bike in neutral after its warmed up it will rev to 11k but the bike stumbles and seems to lose power about 8k just reving. Now I have a hard on to find whats up with this!
and I've taken and opened the gas cap while driving didnt seem to help
It's not what you ride it's that you ride!
1980 Kawasaki KZ250 LTD (current project)
1978 Honda CB400
1987 Honda Elite 50 (speed project)
1978 Honda CB400
Re: No top end
09 Oct 2011 00:27Static timing doesn't assure that the ignition advancer is properly functioning.moke wrote: went and redid the timing (static) it runs better overall but wont rev past 7.5k in gear. Ive noticed when i rev the bike in neutral after its warmed up it will rev to 11k but the bike stumbles and seems to lose power about 8k just reving. Now I have a hard on to find whats up with this!and I've taken and opened the gas cap while driving didnt seem to help
A strobe type timing light is necessary (dynamic timing) to watch the advancer rapidly move forward and backward as rpm is varied by blipping the throttle.
A malfunctioning advancer (stuck in retarded idle position, for example) may result in the reported lack of power at higher speeds.
- moke
Re: No top end
09 Oct 2011 21:42
noticed if i tspe up the air filter (pod filer) and fully choke it i can hit 50mph or 9k in 4th gear but thats it wooo
its even less in 5th. Since the advancer is it serviceable as in i can take it apart, clean and reassemble it?
1978 Honda CB400
1978 Honda CB400
- KZQ
- Administrator
Re: No top end
09 Oct 2011 22:03moke wrote: noticed if i tspe up the air filter (pod filer) and fully choke it i can hit 50mph or 9k in 4th gear but thats it woooits even less in 5th. Since the advancer is it serviceable as in i can take it apart, clean and reassemble it?
If taping the pods up and enriching the mixture helps it means that you're too lean to begin with. Any chance the boot that connects the carb to the engine was also damaged in the recent spill?
Try spraying some WD-40 on everything between the carb and the engine, while it's running. If the idle speed changes you've got an intake leak.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Motor Head
Re: No top end
09 Oct 2011 22:11
No Top End, Problem= Pod airfilter. You need to jet up, or return to stock airbox.
Yes the advancer is servicable, its in the scheduled mainenance section of your manual.
- KZQ
- Administrator
Re: No top end
09 Oct 2011 22:16Motor Head wrote: No Top End, Problem= Pod airfilter. You need to jet up, or return to stock airbox.
I'm with you on the pod filter issue except that he said it ran well for the first week.
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Motor Head
Re: No top end
09 Oct 2011 22:27
I was also surprised with the "POD" post.
- moke
Re: No top end
09 Oct 2011 23:34
Pods that surprising? From my experiences with performance 2strokes I understand that upjetting is required but when I bought the bike it ran 60-65 easy with a pod filter, no stock box on the bike unfortunately when it was bought. I have done vacuum tests with starter fluid and no fluctuation whatsoever.
1978 Honda CB400
1978 Honda CB400
- Motor Head
Re: No top end
09 Oct 2011 23:39 - 09 Oct 2011 23:44
If it took off when you taped up the POD, then maybe you should look at the size of the jets. Then compare to stock and see if they are 2 sizes up on the main. That would be a starting point.
Also if it was dropped by your friend, and the points cover was Knocked Loose, then maybe the advancer is damaged. You should be able to pull off the cover, visually inspect the advancer, and taking your fingers around the outer part of it rotate and release. It should move against spring force and snap back freely.
Last edit: 09 Oct 2011 23:44 by Motor Head.
- moke
Re: No top end
09 Oct 2011 23:48
it didnt exactly "take off" just a slight rpm improvement, If anything its gotten colder here in wisconsin which would cause the bike to run rich yet my plugs a nice brown after a test run from what i can see. I dont know if ambient air temps causing it to run leaner ~80* versus the temp now 60-70* which would richen the mix
1978 Honda CB400
1978 Honda CB400
- Motor Head
Re: No top end
09 Oct 2011 23:53
The colder temp would want more fuel, the air-fuel ratio becomes lean with a cold dense air.
You opened the cap for a venting issue, do you have any in-line filters, or checked the petcock flow?
- moke
Re: No top end
09 Oct 2011 23:59
ignorance showed there had it backwards, I have a petcock filter and in-line which I have check and cleaned and petcock is flowing freely. And I tried the cap just for the heck of it and didnt make a difference. I could try restricting the pod as much as possible to test the mix. But it was acting up before any real temp changes which has me confused in the first place. Possible i may be seaching in the wrong area?
1978 Honda CB400
1978 Honda CB400
