Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2321
Spark plug reading
  • xbmxxx
  • xbmxxx's Avatar Topic Author
Spark plug reading
26 Sep 2011 22:48
#479831
I think this is too lean, but would like a second opinion before I start drilling out jets or whatever it is I have to do.
Its a 76 750 Twin. Pod filters, 2 in to ! with a glasspack. I was hoping maybe I could get away without rejetting as I live at 5300 feet, but I dont think I got that lucky.
76 KZ750B Twin
  • JR
  • JR's Avatar
Re: Spark plug reading
27 Sep 2011 21:03 - 27 Sep 2011 21:04
#480048
in the top picture it looks like it might be between ok and a tad lean. In the bottom picture I see you have B8ES plugs and I think that something like a B6 or B7 is recommended. However, I dont have a twin and dont have experience with twins so dont do anything until a twin owner comes along. How is the bike running currently ?
Last edit: 27 Sep 2011 21:04 by JR.
  • xbmxxx
27 Sep 2011 23:43
#480098
It is hard to explain. It runs great for a while, and then randomly will start running terrible to the point that it wont accelerate, and then wont idle, and then wont run at all. Let it sit a few hours, and bam it runs fine again.
76 KZ750B Twin
  • xbmxxx
27 Sep 2011 23:44
#480099
and I got the b8es from my service manual, maybe the 4 is different.
76 KZ750B Twin
  • MFolks
  • MFolks's Avatar
28 Sep 2011 00:01
#480107
Using the Gas/Alcohol mix most of us are? The fuel will absorb water, making your bike's engine give unusual plug readings.
  • Motor Head
  • Motor Head's Avatar
28 Sep 2011 00:06
#480112
What I see from Kawasaki is the B1-2 takes the 8's. Then the B3-4 takes the 6's. Why they needed to go 2 heat ranges hotter, I don't know. If anything the later bikes would be leaner, which would be hotter combustion. My head hurts.
  • jonnybravo
  • jonnybravo's Avatar
  • Banned
28 Sep 2011 02:38
#480147
the left one looks ok, the right one looks lean, turn fuel mixture screw in a little on that one a recheck
28 Sep 2011 06:11
#480154
xbmxxx wrote: It is hard to explain. It runs great for a while, and then randomly will start running terrible to the point that it wont accelerate, and then wont idle, and then wont run at all. Let it sit a few hours, and bam it runs fine again.
A classic symptom of too tight valve clearances.
Good Fortune! :)
  • T_Dub
  • T_Dub's Avatar
28 Sep 2011 09:10
#480164
They read B8ES, probably says NGK on them on the other side.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
  • jonnybravo
  • Banned
28 Sep 2011 09:24 - 28 Sep 2011 09:26
#480170
yes they do say NGK, the comparable ,Autolite, Champion ,etc have diff numbers,
if ur manual says 8's go with it, I've seen people experiment a little with diff numbers but something like a 4 would way off
Last edit: 28 Sep 2011 09:26 by jonnybravo.
  • T_Dub
  • T_Dub's Avatar
28 Sep 2011 09:35
#480171
Yeah I'd say a bit of air screw fiddling and moving your needle up a shade would do the trick. Like Patton says look at your valve clearances too.
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
  • Motor Head
28 Sep 2011 09:40
#480176
jonnybravo wrote: yes they do say NGK, the comparable ,Autolite, Champion ,etc have diff numbers,
I think he was referring to the 4's as the 4 cylinder models, his is a twin of course, not a 4 heat range plug.
