Warning: Undefined variable $end_tag_params in /home/kzride5/public_html/libraries/kunena/External/Nbbc/src/BBCode.php on line 2321
Spark plug reading
- jonnybravo
- Banned
Re: Spark plug reading
28 Sep 2011 12:00ooooppppsss :blink:Motor Head wrote:I think he was referring to the 4's as the 4 cylinder models, his is a twin of course, not a 4 heat range plug.jonnybravo wrote: yes they do say NGK, the comparable ,Autolite, Champion ,etc have diff numbers,
if ur manual says 8's go with it, I've seen people experiment a little with diff numbers but something like a 4 would way off
- Treewizard
28 Sep 2011 20:00
i dont have a twin but i say Johnybravo's avatar looks like a shaved girl weener sharading as a hamburger!!!
:laugh: :laugh: :laugh:
1983 KZ 750 shaft
2002 ZRX 1200R
Raleigh NC
2002 ZRX 1200R
Raleigh NC
- JR
28 Sep 2011 20:09 - 28 Sep 2011 20:10Patton wrote:xbmxxx wrote: It is hard to explain. It runs great for a while, and then randomly will start running terrible to the point that it wont accelerate, and then wont idle, and then wont run at all. Let it sit a few hours, and bam it runs fine again.
A classic symptom of too tight valve clearances.
Worth checking your valve clearances
If your manual says B8ES then go with it. Tweaking the air fuel mixture might help but from the colour of your plugs I would not think that lean is the cause of the problem you described above.
Last edit: 28 Sep 2011 20:10 by JR.
- jonnybravo
- Banned
28 Sep 2011 20:48JR wrote:Patton wrote:xbmxxx wrote: It is hard to explain. It runs great for a while, and then randomly will start running terrible to the point that it wont accelerate, and then wont idle, and then wont run at all. Let it sit a few hours, and bam it runs fine again.
nobody said it was, just talking about the plug reading
- Gary - K7GLD
- 1983 1100LTD
01 Oct 2011 14:06 - 01 Oct 2011 14:07
YUP - looks more like a minor carb or other issue than plugs - Like Mfolks says, the junk gas we are forced to use can confuse plug reading - I use non-ethanol premium in most of my stuff - a bit more cost - but far less fuel system and engine running issues...
John Day area - Eastern Oregon
Restored 1983 Kawasaki 1100LTD
Last edit: 01 Oct 2011 14:07 by Gary - K7GLD.
