What am I missing?
  • Onetype
  • Onetype's Avatar Topic Author
What am I missing?
25 Sep 2011 03:20
#479360
1979 Kz650E
Adjusted the clutch per manual, it has a nice pull to it. Starts the bike no problem, but with the clutch depressed, and in gear I can not move the bike. What am I missing?
  • clutch
  • clutch's Avatar
  • I wish I had a tad more patience to do it better!
Re: What am I missing?
25 Sep 2011 03:38 - 25 Sep 2011 03:39
#479363
Clutch cable might be slightly too LOOSE. Make sure you have a slight play in it before it engages. In other words, you should be able to pull the lever very slightly, I believe the manual says 2-3mm of play, before it actually engages the clutch springs. Other than that, I will defer to the more experienced members.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Last edit: 25 Sep 2011 03:39 by clutch.
  • Onetype
25 Sep 2011 03:52 - 25 Sep 2011 03:53
#479364
I was thinking similar, as it's not fully engaging to allow me to move it, but it seems very tight already.
I loosened the nut on the cable (moving it further away from the barrel, thus making the pull on the lever harder), and adjusted the pin on the case. (tightened until it gets tough, then back off 1/2 inch, and tighten adjuster nut.
Maybe I need to go back and adjust at the lever?
Last edit: 25 Sep 2011 03:53 by Onetype.
  • clutch
  • clutch's Avatar
25 Sep 2011 03:58
#479365
Onetype wrote: I was thinking similar, as it's not fully engaging to allow me to move it, but it seems very tight already.
If I'm not mistaken, the clutch cable should be loosened when you adjust the pushrod (the pin on the case), then tightened with the 2-3 mm play. I had the opposite issue with mine, where my clutch was slipping. I found the pushrod adjustment to be touchy/tricky on mine and just tried different adjustments until it didn't slip anymore. I wish I could be more help...though I'm sure the more experienced kz gurus will chime in shortly to help you get it adjusted properly. :)
Wish List:
  • Onetype
25 Sep 2011 12:36
#479420
loosened as in move the adjusting nut on the cable closer to the barrel?
25 Sep 2011 12:46 - 25 Sep 2011 12:47
#479422
back off 1/2 inch - - - hoping that's actually meaning 1/2 turn.
As to not rolling while in gear with the clutch lever squeezed, this isn't unusual when the engine is cold. Because the clutch plates are likely "sticking together."
Same reason the bike may lurch forward slightly when first putting it into gear after starting a cold engine. Just nature of the beast.
Good Fortune! :)
Last edit: 25 Sep 2011 12:47 by Patton.
25 Sep 2011 12:49
#479423
  • Onetype
25 Sep 2011 14:37 - 25 Sep 2011 14:40
#479442
Yes, 1/2 turn. Not inch. This is with the bike off though.
Thanks for the info, the motor has only been running about 5 mins in the past month. I'm going to re adjust it, and let it warm up and see what happens.
Thanks Patton.
Last edit: 25 Sep 2011 14:40 by Onetype.
  • MFolks
  • MFolks's Avatar
25 Sep 2011 14:51
#479443
What type/grade of engine oil being used?
Best Oils To Use In Your Bike (Just My Opinion)
Engine oil : The commercial grade oils are clearly superior to the mass market oils. For the best protection in your bike or car, use Shell Rotella Synthetic, available at Wal-Mart in blue containers . For the best petroleum oil you can buy, get Shell Rotella T, Mobil Delvac 1300, or Chevron Delo 400, available at any auto parts store.
On the back of most oil cans is a circular stamp with the certification. Avoid oils that say "energy conserving" in the bottom half of the donut. These oils contain friction modifier additives that could cause clutch slipping over time. The EPA mandated certain gas mileage, so the auto makers turned to the oil manufacturers who came up with friction modifiers of the oil to meet these new standards. All XXw-20 and XXw-30 oils are energy conserving, and should not be used in your motorcycle. Don't buy any oil additives like STP or Slick-50.
  • ramtough_63
  • ramtough_63's Avatar
25 Sep 2011 15:03
#479444
I use mobile 1 been told thats not a good idea ran it in my 02 FLSTS and run it in my 84 Goldwing with no problems however have some leaks since using it on my 78 KZ (I am thinking normal due to the abuse and years it sat)
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • TexasKZ
  • TexasKZ's Avatar
25 Sep 2011 18:31
#479470
Mobil 1 is fine if it is the motorcycle specific one.
The following user(s) said Thank You: ramtough_63
25 Sep 2011 19:04
#479477
Onetype wrote: ...the motor has only been running about 5 mins in the past month. I'm going to re adjust it, and let it warm up and see what happens....
After the initial clunk/lurch when first shifting into gear after starting a cold engine, the issue usually disappears until the next cold engine start.
The clunk usually separates the "sticky" clutch plates in a cold engine.
Good Fortune! :)
