Oil sight glass
  • baldy110
  • baldy110's Avatar Topic Author
Oil sight glass
07 Sep 2011 01:06
#474799
OK, is there trick to installing the oil sight glass on the clutch cover without breaking the glass? I have broken two.
  • MFolks
  • MFolks's Avatar
Re: Oil sight glass
07 Sep 2011 01:46
#474802
Installing it dry or with some lubrication? Contacted www.z1enterprises.com for advise? Are you pushing with a socket or your thumb?
  • otakar
  • otakar's Avatar
Re: Oil sight glass
07 Sep 2011 10:57
#474843
I have installed a lot of them and never broke one. I use a Nylon plastic rod that is almost the full size of the glass and I lube the rubber with some spit. It slides right in.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Re: Oil sight glass
07 Sep 2011 11:04
#474844
otakar wrote: I have installed a lot of them and never broke one. I use a Nylon plastic rod that is almost the full size of the glass and I lube the rubber with some spit. It slides right in.
Could you rephrase that? :laugh:
Good Fortune! :)
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Oil sight glass
07 Sep 2011 11:18
#474849
:woohoo: :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • ed spangler
  • ed spangler's Avatar
  • Tennessee Z
Re: Oil sight glass
07 Sep 2011 12:50
#474869
HMMMMMMMM.......?? Welll.....Little "SPIT" goes a long way!!
Interesting!
Have 1975 Kawasaki Z1-B & 2003 Harley Davidson Heritage Softail Classic
Had Hondas, Harleys and many ,many Z Series Kaws both Std. & LTD's
  • baldy110
Re: Oil sight glass
07 Sep 2011 13:29
#474873
Thanks for advice. And Otakar, keep your sex life to yourself.
  • Old Man Rock
Re: Oil sight glass
07 Sep 2011 13:48 - 07 Sep 2011 13:49
#474877
Otto... Using your fingers or something else... :blink:
Remind me not to touch Ottos bike again.... :whistle:
I guess it adds new meaning to Ottos additives.... ewwwwwwwwwwwwwwwwwwwww... :pinch:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 07 Sep 2011 13:49 by Old Man Rock.
  • Tommotbird
  • Tommotbird's Avatar
Re: Oil sight glass
07 Sep 2011 15:37
#474901
Any tips on removing the sight glass on from the cover on a KZ750 Ltd without breaking it. I know it is just a push fit but it seems stuck in there pretty fast.
Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: Oil sight glass
07 Sep 2011 17:28
#474919
soemone said to use a paint stirring stick and trim it down until it fits through the slot then just push it out.
hth,
