ide jumps way up!
- newowner79kz750b1
- 79 kz750b4
ide jumps way up!
11 Aug 2011 13:42
i have a 79 kz750 twin. i just put a new coil in yesterday. started right up. took a for a ride. rode great other then i have to adjusting the carbs a tad to get the mixture right. any way. i was at a stop light and out of no where the idle jumped up to around 5,000 rpms and i have no idea why. before the coil i cleaned the float bowls, cleaned the jets ect. this problem has never happend until i put the new coil in. i dont think its an air leak either. not sure on what to look for or do. thanks everyone!
- cobura
- forever 2 wheels
Re: ide jumps way up!
11 Aug 2011 13:47
Maybe....check your vaccuum lines. I had the same thing happen to me before. I was out riding and the vaccuum line slipped off the petcock. It started to suck air and revved out really high.
1979 KZ650B3
- clutch
- I wish I had a tad more patience to do it better!
11 Aug 2011 14:19 - 11 Aug 2011 14:19
Could be a symptom of a lean mixture. Also, on my 750 4 cyl, there is an idle speed adjustment knob under the carbs. If idle speed is set too high, it may have a high or hanging idle as well. I would check that first.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I say more?)
Wish List:
Last edit: 11 Aug 2011 14:19 by clutch. Reason: fixed a typo! :)
- Bwildcat
17 Aug 2011 17:09
Just the subject/advice I was looking for... wife wasn't happy that it started making funny noises the first day I got it...
Thanks guys.
Thanks guys.
1980 KZ750-H LTD (first bike)
- Bwildcat
Re: idle jumps way up!
17 Aug 2011 23:06
Is there anywhere else that the vacuum leak could be happening? I don't even know enough to know if that sounds stupid... VERY new to the motorcycle/ shade tree mechanic business.
I played with the idle adjustment knob and got very little (false hope) response. The next time I fired it up it went right back to the 4000 RPM idle.
I also looked at both lines coming out of the fuel petcock and they look to be in pretty good shape on both ends and middle.
- garyprather
17 Aug 2011 23:24
If no vacuum leak is found I would look and you linkage to your carbs. If the carbs are not set right your choke will not make a difference. The bike will run as if you have the en-richer,/ choke on. The carbs would have to be way out of sync at that point though.
18 Aug 2011 10:04
There could be a leak where the intake manifolds meet the head, where the carbs meet the intake manifolds, and the plug for the vacuum port on the other carb may have failed. With the engine running, carefully spray brake cleaner around each of these places. A sudden change in rpm will indicate a leak.
The following user(s) said Thank You: Bwildcat
- Bwildcat
19 Aug 2011 15:15
It looks like part of one of the seals (gaskets?) may have gotten sucked into the intake some. Hoping it just disintegrated and fell OUT but my 3 day history with it has gone from bad to worse so I'm not holding my breath.
19 Aug 2011 15:21
Which seals or gaskets do you mean? Pics might help.
- Bwildcat
19 Aug 2011 15:30
I'll dig around for the correct camera cable... they look like little rubber seals between the 3rd carborator and what I think is the cylinder head (sorry if I'm directing my help the wrong way, should have taken a few more shop classes :pinch: )
- Bwildcat
19 Aug 2011 15:46
The pictures zoom into the problem (?) spot. The third picture is of the 4th carb on the outside and what the others look like. The fourth picture is the 3rd carb (the one that looks screwy).
Help?!?!
Thanks guys!
Help?!?!
Thanks guys!
- Bwildcat
19 Aug 2011 15:50
Break it to me gentle doc... how bad is it.
