Kick start woes.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Kick start woes.
04 Jul 2018 18:28 - 04 Jul 2018 18:29
#786430
If you pull the clutch you disengage the main shaft (crank gear drive) from the output shaft. The kick start gear engage to the output shaft gear to kick start the engine (without pulling clutch).
Last edit: 04 Jul 2018 18:29 by Scirocco.
The following user(s) said Thank You: bikerguy
  • bikerguy
  • bikerguy's Avatar
06 Jul 2018 08:56
#786511
Scirocco wrote: If you pull the clutch you disengage the main shaft (crank gear drive) from the output shaft. The kick start gear engage to the output shaft gear to kick start the engine (without pulling clutch).
Awesome!
1979 KZ1000 LTD
——— Previous Rides: Seca 550, GS400, GS750, RZ350, XL 250, Hurricane 1000, ZX900, ZX-10, Shadow Spirit 750
