resistor plugs or not
- jga2z
- 2 wheels good ,4 wheels bad
18 Jun 2011 16:56
My 82 LTD 1000 has had the stock coils rewired and I put MSD 8mm copper core wires on after whittling down outer insulation layer and enlarging the holes in stock caps on the coils.
They have MSD plug boot ends so no stock resistor ends. Coils check at 2.8 ohms
I've been running NGK B8es plugs which after multiple cleanings due to rich carbs (hopefully fixed now)1 or 2 don't seem to fire very well if at all.
The question is whether or not I need resistor plugs like BR8ES or can I run the B8ES?
Can't get Denso's locally and I won't use Champions so it's NGK or??? need options.
currently 1982 LTD1000 UNI dual throat pods, MAC header Supertrapp muffler. Shoei fairing.
The good old days: 1977 KH 400 triple, 1978 KZ650B all the basic mods, My avatar a 1980 LTD 750, ditto on the mods
- bountyhunter
Re: resistor plugs or not
18 Jun 2011 20:16 - 18 Jun 2011 20:17
Since your bike has no on board computers or sophisticated electronics, it would probably run OK without resistor plugs. It will put out a lot of radio noise.
Last edit: 18 Jun 2011 20:17 by bountyhunter.
- KZ250LTD
Last edit: 13 Feb 2012 18:21 by KZ250LTD.
- otakar
18 Jun 2011 22:42
I run no resistance at all and have no problems with using a GPS or on-board video camera. The spark is also much stronger. I just love annoying the pricks in their fancy cars and the overpowering stereos. :evil: :woohoo: But than I am also the asshole that has a cellphone jammer on my bike. :whistle:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Linsk
- Ron L
18 Jun 2011 23:21
Where can i get a cell phone jammer. I've ben wanting one for a while.
1980 KZ 1000 A4 1075 kit 1980 KZ 1000 st 2400 orig miles 1982 GS 1100 E sold 2017 ZX 14R
- otakar
18 Jun 2011 23:40 - 18 Jun 2011 23:42
I bought mine on line. The more bands it jams the better.
www.espow.com/jammers/security-surveillance-jammer.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Jun 2011 23:42 by otakar.
The following user(s) said Thank You: Linsk
- jga2z
Re: to resist or not
18 Jun 2011 23:52
Well I guess I can hope for better spark with no resistance in the ignition secondary.
Just as an experiment to judge the iffy NGK plugs I got Autolite 4054's (spec for this bike)
No difference.
Time for a new thread.
No difference.
- otakar
19 Jun 2011 08:40 - 19 Jun 2011 11:56
The best plug to use that I have found is the denso W24ESU. Those are identical to ACCEL 142. Here is a thread we did some time ago.
kzrider.com/forum/4-electrical/351334-wh...plug-gap-do-you-run-
I dont think the plugs are the problem though. 2.8 Ohms on the coils is the very upper limit of resistance. I would replace the coils with a set of Dyna 2.2 Ohm Gray coils. These are the correct replacement for that bike, because the ignition system is a 2.2 Ohm system. Did you also check the voltage going to the coils while the bike is running? If you have below 12V, you have a problem in the wiring harness.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 Jun 2011 11:56 by otakar.
- jga2z
19 Jun 2011 12:55
I did the rewire of the coils with a relay direct from battery.
I would think it would run passable with these coils but the plugs had never looked like they were firing clean as they should.
- otakar
19 Jun 2011 13:55 - 19 Jun 2011 13:59
I would first make sure that your ignition is at 100% before you start messing with your carburetors. Make sure that the advancer is working properly. Make sure that the pulsing coils are not intermittent. Make sure that the ignition coils and wires are at 100%. Make sure that you have a bright blue spark. Than go back to your carburetors (if at this point you even have to)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 19 Jun 2011 13:59 by otakar.
- patti99
17 Aug 2011 01:28
I bought one from Jammerall a few weeks ago.
Many more cell phone jammer www.jammerall.com/ for your choice
- Kapahulu
17 Aug 2011 14:30Wow! They have some as cheap as $37 bucks! Seems like a great thing to be carrying on your motorcycle. Distracted drivers will get dropped calls. It may make them more distracted for a moment but then they'll get off the phone.otakar wrote: I bought mine on line. The more bands it jams the better.
2strokeworld.com
2strokeworld.com
