1015 max cylinder size
- stonemaster
- Visitor
- Kraz1
sorry dad
I don't call ya Son cause your mine... I call ya Sun cause you Shine... :laugh:
- Stu Pidasole
- if you aint mod'n, you aint rock'n!
- Thank you received: 1
thanks..the guy said its less than 71 and more than 70. painted black, but i dont fking care.Stu Pidasole wrote:
. what is the largest the sleeve can be so i can still bore out to 1075?
stonemaster wrote:Kraz1 wrote:
1045cc 2.795 and still allows you to go to 1075cc 2.835... You Drunk today?
I've heard u cant get 1045 kits anymore
Well the original question was as quoted above... And Wiseco would have probably removed them from their website if not available, although I could be wrong...
Either way,Big Joe wants to know what size the sleeves/block could/would be in mm's and would still allow him to Bore to 1075cc's.
The answer would be 1045cc's 2.795/71.00mm's
- gearheadmm
- MUCH MORE BOOST..........I mean BRAVO
- Thank you received: 11
:laugh: :lol:I never installed those in between bore pistons. Either make it big or leave it alone.... In between is like not knowing if your gay or bi... :woohoo:
General Joeseph Dunford FOR PRESIDENT!!!
69.46.28.106/forum/11-projects/413221-80-kz-1000-st-recycled
- Thank you received: 2098
Am thinking 71MM bore is 1045cc.
[Click on image to enlarge view.]
If a well-worn "1045" is being considered for boring to 72MM, am thinking it wouldn't hurt to measure with bore gauge to assure enough meat remaining in each liner. It's getting pretty thin at 72MM, especially where FSM says max is 71MM.
Would defer to Kraz1's opinion about this.
- gearheadmm
...the guy said its less than 71 and more than 70....
Isn't this a typical stock 1015cc KZ1000 block that started life at 70mm and which has since worn to something less than 71mm?
KHI provided two piston over-sizes for KZ1000, the first being 0.5mm and the next being 1.0mm.
Presupposing normal wear, the less than 71mm should allow boring to 72mm for 1075cc.
- lemo32
- The Price of Cool aint cheap
1979 kz 1000 06 katana 750
- Stu Pidasole
whats a busa? never heard of it.:dry:Joe when you get that busa can I have your kz
- DoubleDub
- Visitor
- DoubleDub
- Visitor
- PLUMMEN
- Thank you received: 104
do a stock rebuild with welded crank and replace anything worn.throw a set of 8:1 1015s in there with a stock head with good valve springs and stock cams with a turbo!
you can tune it to run just like a stock motor in hot weather or crank a few lbs of boost into it and have an instant 1075 killer on pump gas
