1015 max cylinder size
  • Stu Pidasole
  • Topic Author
  • if you aint mod'n, you aint rock'n!
05 Mar 2011 15:32 - 05 Mar 2011 15:35 #435249 by Stu Pidasole
1015 max cylinder size was created by Stu Pidasole
i got a guy who has a lot of blocks. most are bored allready. i told him i need a 1015 virgin at 70mm. what is the largest the sleeve can be so i can still bore out to 1075?
Last edit: 05 Mar 2011 15:35 by Stu Pidasole.
  • larrycavan
  • Visitor
05 Mar 2011 15:34 #435251 by larrycavan
Replied by larrycavan on topic 1015 max cylinder size
Stu Pidasole wrote:
i got a guy who has a lot of blocks. most are bored allready. i told him i need a 1015 virgin at 70mm. what is the largset the sleeve can be so i can still bore out to 1075?
1075 is the largest streetable, safe bore. There's an 1105 kit but you don't want that, especially in Florida.
05 Mar 2011 15:36 #435254 by Kraz1
Replied by Kraz1 on topic 1015 max cylinder size
1045cc
  • hocbj23
  • Visitor
05 Mar 2011 15:41 #435255 by hocbj23
Replied by hocbj23 on topic 1015 max cylinder size
Joe: When u get through farting with this build,you could have bought the baddest 'Busa in the USA and blown people off the road from Miami to Boston.Why dont u quit farting around and get Larry to build u the motor u want and quit wasting time and money chasing rabbits.There are more rabbits than u got time and money I assure u.bj
  • Stu Pidasole
  • Topic Author
05 Mar 2011 15:42 #435256 by Stu Pidasole
Replied by Stu Pidasole on topic 1015 max cylinder size
he wants to know when he measures the sleeve what it the # in mm needs to be to make it a stock 1015. is it 70mm up to 73mm? whats the max amout allowed? i still want to be able to bore it to a 1075.
05 Mar 2011 15:43 - 05 Mar 2011 17:13 #435257 by Patton
Replied by Patton on topic 1015 max cylinder size
KZZONE is your friend: :cheer:
Click > kzzone.com/pistons.html
1075cc 2.835" 72MM KZ1000 cylinder
The largest the sleeve can be is smaller than the 2.835" 72MM bore for 1075cc.
Good Fortune! :)
Last edit: 05 Mar 2011 17:13 by Patton.
05 Mar 2011 15:44 #435260 by Kraz1
1045cc 2.795 and still allows you to go to 1075cc 2.835... You Drunk today? :)
  • stonemaster
  • Visitor
05 Mar 2011 15:53 #435266 by stonemaster
Replied by stonemaster on topic 1015 max cylinder size
I've heard u cant get 1045 kits anymore
  • larrycavan
  • Visitor
05 Mar 2011 16:00 #435272 by larrycavan
I never installed those in between bore pistons. Either make it big or leave it alone.... In between is like not knowing if your gay or bi... :woohoo:
  • Stu Pidasole
  • Topic Author
05 Mar 2011 16:05 #435275 by Stu Pidasole
i might be before the end of tonight...:laugh:
  • Stu Pidasole
  • Topic Author
05 Mar 2011 16:06 #435276 by Stu Pidasole
a busa? really man...not my style. but i am thinking about what you said about Larry.:dry:
05 Mar 2011 16:11 #435278 by Kraz1
Well the original question was as quoted above... And Wiseco would have probably removed them from their website if not available, although I could be wrong...
Either way,Big Joe wants to know what size the sleeves/block could/would be in mm's and would still allow him to Bore to 1075cc's.
The answer would be 1045cc's 2.795/71.00mm's
