left is dead at idle
- 750deuce
27 Feb 2011 20:01 #433881
by 750deuce
left is dead at idle was created by 750deuce
i got the 79 750 twin and the left side isnt firing at idle, but when u give it some gas at about 4-5000, it comes to life. or when your runnin low rpms and fire down on it, itll go then but both never fire inder 1500. im thinkin a weak coil, can anyone else confirm
- Frankn9
27 Feb 2011 21:26 #433897
by Frankn9
Replied by Frankn9 on topic left is dead at idle
maybe check that your carbs are sync'd, perhaps the left one is closed at lower throttle settings? I would think a bad coil would work at idle and cutout as the load increased but sometimes coils do strange things. good luck
- 750deuce
27 Feb 2011 21:39 #433900
by 750deuce
Replied by 750deuce on topic left is dead at idle
they arent that bad if so because it gets better as it warms up
- Thank you received: 2098
27 Feb 2011 21:51 #433902
by Patton
Replied by Patton on topic left is dead at idle
If not already done, would:
Perform compression test;
Check and assure valve clearances to specs;
Visually observe brand new plugs for quality fat blue spark;
Assure ignition timing is correct;
Assure advancer is properly functioning;
Check for voltage leaks in old hard worn-out plug wires (may spray water mist over coil and plug wires with engine running in a dark garage);
Assure air filter(s) clean, clear, unobstructed, and not over-oiled (if applicable);
Lastly, clean carb pilot circuits.
- bountyhunter
- Thank you received: 337
27 Feb 2011 21:58 - 27 Feb 2011 22:01 #433903
by bountyhunter
Replied by bountyhunter on topic left is dead at idle
It can't be the coil because the same coil fires both plugs on a twin. Clean fuel system, sync carbs and make sure the pilot jets and passages are clear.
Valve/compression check always a good idea.
If you do want to change the coil, Z1 sells an EMGO 4 Ohm replacement for $36. That's what I am running on my '79 750 twin.
Last edit: 27 Feb 2011 22:01 by bountyhunter.
