- Thank you received: 12
Will 78 KZ1000 valve cover fit Z1
- lewisj
26 Feb 2011 15:50 #433593
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Vance&Hines header/ exhaust
29mm smoothbores w/pods
ZR7S 41mm Front Forks with 17" wheels
Will 78 KZ1000 valve cover fit Z1 was created by lewisj
Hi guys! Found a small crack in my valve cover near the rear left bot. It was spewing oil big time. Will a 78 KZ 1000 valve cover fit correctly on a 73 Z1? Thanks in advance.
Jim
Jim
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- peter1958
- Banned
- Thank you received: 198
26 Feb 2011 15:53 #433595
by peter1958
Replied by peter1958 on topic Will 78 KZ1000 valve cover fit Z1
Yes
- DFIGPZ
- Thank you received: 122
- larrycavan
- Visitor
26 Feb 2011 16:41 #433606
by larrycavan
Replied by larrycavan on topic Will 78 KZ1000 valve cover fit Z1
lewisj wrote:
If you have performance cams in the bike now, you might have to grind out the + marks inside the 78 valve cover for lobe clearance.
Jim
- lewisj
26 Feb 2011 17:40 #433620
by lewisj
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
Replied by lewisj on topic Will 78 KZ1000 valve cover fit Z1
Thanks guys, I thought so , but wanted to make sure. I will definitely need to grind out the X's!
Thanks again, Jim:)
Thanks again, Jim:)
1075cc MTC kit
Andrews 3X cams
ZRX 1200 swingarm
- Jeff.Saunders
27 Feb 2011 04:05 - 27 Feb 2011 04:06 #433656
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Will 78 KZ1000 valve cover fit Z1
As others said, it will fit fine. The reverse is not true though. You cannot use a Z1 valve cover on the KZ1000's without changing out the top idler assembly. The KZ1000 covers have a modified casting where the center section has some 'blisters' to go around KZ1000 version of the top idler assembly.
Z1 Ent on Facebook,
Last edit: 27 Feb 2011 04:06 by Jeff.Saunders.
