Installing engine
- dcil
25 Feb 2011 20:48 #433480
by dcil
Installing engine was created by dcil
I'm in the process of building a 1982 kz750 twin into a chopper. I've cut the side bars out that follow the backbone in preperation for raking, plus it gives more room for engine removal/installation. I pulled the motor out this evening(major pain by myself). After the framework and paint are done, how is the best way to get it back in there without raping the paint? I took it out laying on it's side, but it fits so close I scratched the sidecover on the frame. There has to be a trick that I'm missing. Thought about pulling the head, but thats a whole other can of worms I don't want to open unless I have to. Any input will be greatly appreciated.
- purls
25 Feb 2011 21:00 - 25 Feb 2011 21:02 #433482
by purls
1983 KZ750 Spectre
1978 KZ650B2A
Replied by purls on topic Installing engine
1983 KZ750 Spectre
1978 KZ650B2A
Last edit: 25 Feb 2011 21:02 by purls.
- PLUMMEN
- Thank you received: 104
25 Feb 2011 21:10 #433483
by PLUMMEN
Replied by PLUMMEN on topic Installing engine
i normally lay motor on its side on a rug and lower frame over it,wrap frame tubes to protect them.
removing exhuast studs before installing motor also helps
- Old Man Rock
- Thank you received: 225
26 Feb 2011 07:36 - 26 Feb 2011 07:37 #433503
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Installing engine
With Frame stripped (front end & rear swingarm off), cylinder/head/carbs off...
Frame on blanket laying vertical....
Frame tubes where engine slides in bubble wrapped/tapped...
Slide lower engine into place just off right side as sitting over frame...
Left arm inside frame, right arm outside of frame...
2-4" lift up and slide frame left into place...
Shift/move/rotate engine in mounting hole positions.
Insert engine mounting bolts....
Eat your spinach, helps if you're a strong sonsabitch as well.... :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 26 Feb 2011 07:37 by Old Man Rock.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
26 Feb 2011 07:44 #433508
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Installing engine
PLUMMEN wrote:
I just pick the whole damn engine up and hold in place with my lefthand, while I run the bolts thru with the other. :laugh: :laugh: :laugh:
No seriously, I do the same thing, but with an old mattress and some wood pieces to shim the motor where I want it.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- PLUMMEN
26 Feb 2011 08:59 #433530
by PLUMMEN
i used to be superman also! :laugh:
