Putting a KZ1000 engine in a KZ900
- Brady 154
22 Feb 2011 12:03 #432718
by Brady 154
1976 KZ900 LTD, resto-mod
-1075 Piston Kit
-PSP 3X Cams (degreed to 106)
-Mikuni RS34 Carbs
-Pod Air Filters
-Dyna S Coils and Ignition
-Race Tech Valve Cartridge Emulators up Front
-Ohlins Shocks out Back
Putting a KZ1000 engine in a KZ900 was created by Brady 154
Hi all, I am new to this forum and I did search for the answer to this question, but I did not find it. I am beginning a resto mod project on a 1976 KZ900 LTD, because I had this same bike when I was a teenager. The engine case is cracked on my project bike. I plan to do a lot of performance mods to the bike anyway, so I was thinking of using a KZ1000 motor instead of another KZ900. In addition to more power (I assume), I was thinking it might be easier to get KZ1000 parts since they are newer and more abundant (again I assume). I am greatly interested in any thoughts and input on this. My questions are if a KZ1000 motor will bolt right into a KZ900 frame or not, will it use the same wiring harness, and are there other issues with making this swap? thanks
Brady
Brady
-1075 Piston Kit
-Mikuni RS34 Carbs
-Pod Air Filters
- TomW
- Keep the blue side up.
- Thank you received: 52
22 Feb 2011 12:16 #432720
by TomW
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
Replied by TomW on topic Putting a KZ1000 engine in a KZ900
Oh boy. Another unfortunate looking for cases. You are at least the 3rd. in a week. The engine cases share the same part # from '74 to at least '78. Rather than a complete engine, replacement cases would be a lot less costly. The 900 cylinders can be bored out to 1015 with the stock sleeves. Larger if new sleeves are installed. Good luck with your build.
- PLUMMEN
- Thank you received: 104
22 Feb 2011 12:30 #432724
by PLUMMEN
Replied by PLUMMEN on topic Putting a KZ1000 engine in a KZ900
any 73-80 900/1000 motor will bolt in,79-80 has differant charging system which is an easy fix.
major differance between 900/1000 is going to be the heavier crank in 77/78 1000 and bigger bore.
some 79-80 motors have stronger cranks and trans gears,but normally its not needed unless youre building a turbo.
- Brady 154
22 Feb 2011 12:38 #432728
by Brady 154
-1075 Piston Kit
-Mikuni RS34 Carbs
-Pod Air Filters
Replied by Brady 154 on topic Putting a KZ1000 engine in a KZ900
That's great information--thank you. I prefer to keep the internal rotating parts lighter (i.e. the crank), so I might be better off using a bored out KZ900 motor like TomW above suggested huh? Can you still get OEM parts for these bikes also?
-1075 Piston Kit
-Mikuni RS34 Carbs
-Pod Air Filters
- DoubleDub
- Visitor
22 Feb 2011 12:48 #432733
by DoubleDub
Replied by DoubleDub on topic Putting a KZ1000 engine in a KZ900
Depends on the parts. kawasaki.com has a parts diagram and lists parts that are discontinued. Z1Enterprises.com is a great source for parts, both OEM and aftermarket. Great service too.
- PLUMMEN
22 Feb 2011 13:04 #432737
by PLUMMEN
Brady 154 wrote:
you can probably find a 1000 motor thats rebuildable for $300- 400,then take the 900 crank and use it with 1000 topend.That's great information--thank you. I prefer to keep the internal rotating parts lighter (i.e. the crank), so I might be better off using a bored out KZ900 motor like TomW above suggested huh? Can you still get OEM parts for these bikes also?
- mtbspeedfreak
- Thank you received: 36
22 Feb 2011 18:45 #432813
by mtbspeedfreak
2000 ZRX 1100
1976 KZ 900- Daily Driver
Replied by mtbspeedfreak on topic Putting a KZ1000 engine in a KZ900
Slightly off topic... So it's possible to mount a KZ1000 engine in a KZ900 frame.
Now, what would go into mounting a GPz head on that KZ1000 engine???? :ohmy: Do GPz heads fit on a "non-J-motor" without machining?
Maybe Larry can step in to answer this: If you were planning on building a runner (not a drag bike), would the cost to benefit ratio be greater to make a GPz head work, or would one be better off sending the KZ head to Larry?
2000 ZRX 1100
- PLUMMEN
22 Feb 2011 18:52 #432816
by PLUMMEN
by the time you buy pistons and other odds and ends to make the gpz head work id say youd be money ahead porting the stock kz head and using your stock pistons,but it depends on what youre trying to achieve.
